Cold Floor - Fiberglass RV
Old 10-13-2018, 10:38 AM   #1
Trailer: Meerkat
Cold Floor
Up at 6,000ft in Yosemite, the camper stayed warm but the floors were freezing. Any suggestions on thermal covering or carpet to reduce the cold?
Lfrye is offline   Reply With Quote
Old 10-13-2018, 11:15 AM   #2
Trailer: Scamp 16, previously Scamp 13
None
Any cheap throw rugs work really well, especially the ones sold as bath matts (they usually have a foam backing and are fluffy) or the rubberized mats they sell for just a couple of bucks at Dollar Stores - the ones for in front of the kitchen sink.
Other folks have bought a set or two of the interlocking foam mats (look like puzzle pieces) that they sell at Home Depot or Lowes. These are easy to trim to the proper size and easy to pick back up when the weather warms.
If your floor is similar in design to the Scamp:
Finally, the side of the drop from the dinette area to the main floor, and the area under the kitchen cabinets is often just vinyl over the steel frame member - conducts a LOT of cold. I have rolled up a blanket and stuffed it under the toe kick area, and drape a fleece throw to cascade over the step from the dinette down. These two temporary measures helps immensely when sitting in the trailer during the cold weather. Also, don't forget covering the windows and ceiling vents with reflectix - this also helps a lot and reduces condensation.
LyleB is online now   Reply With Quote
Old 10-14-2018, 08:35 AM   #3
Paul O.'s Avatar
Trailer: '04 Scamp 19D, TV:Tacoma 4.0L 4door, SB
We use two carpets in our Scamp - a good one and a lousy one. The lousy one is a small cotton throw rug in front of the door - cotton is very cold on bare feet. The good one is a wool runner that goes the whole length of the galley. The ends have to be folded to fit, but that is not a problem. That good one is warm on bare feet, being wool. Both are easy to pull out, shake the dust, dirt or crumbs out of them and throw them back in. Since we have the original Scamp carpet, these rugs tend to creep towards the rear, but I do not think it is a big deal to pull them back in place by a couple of inches once a day, or so.
The cotton rugs are cheap to begin with, the wool rug was used and hence it was also quite cheap.
Old 10-14-2018, 08:41 AM   #4
Interlocking foam squares, available in a range of colors and woodgrain. Trim to fit. Add a throw rug on top if desired.
https://www.greatmats.com/tiles/inte...s-wood-rev.php
Name:	Foam floor tiles.jpg
Old 10-14-2018, 11:11 AM   #5
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Attachment 125416
We used these in our Lil Snoozy this summer during our Alaska tour for 4 months. They really worked great for keeping the feet warm. No socks or slippers needed, AND the added comfort for the knees when ever we had to get things out of the refrigerator or bottom cupboards was a welcome bonus. The problem we had with these was with the finish. Shoes grip very well with the surface of these mats, and when you turn, the surface rips off over time..
Dave and Paula
Old 10-14-2018, 11:30 AM   #6
New Mexico
The Interlocking foam mats are great. As shown by John in AZ, you can even get some woodlook ones. We camped once in cold weather without them- our feet froze. Next trip after adding the mats our feet were nice & toasty. They also cushion the floor for the dog to sleep on & can be removed easily & washed if necessary.
Poodlesrule is offline   Reply With Quote
Old 10-14-2018, 12:16 PM   #7
Sid
Sid's Avatar
Trailer: Parkliner 2014 V6 Jeep Cherokee
Under carpet heating has been discussed here many times. If you are just looking to take the chill off your feet and are at a site with electricity this might be what you are looking for: https://cozywinters.com/shop/rug-hea...iABEgKtY_D_BwE
Sid
“You can’t go back & change the beginning but you can start where you are & change the ending” C.S. Lewis
Sid is offline   Reply With Quote
Old 10-14-2018, 12:30 PM   #8
Originally Posted by Poodlesrule View Post
The Interlocking foam mats are great. .
.. Here is what I did with the foam tiles. It worked fine for one trip, then I came home and Tropical Storm Michael came to visit. Floor got wet, I think from the furnace vent. Water was trapped between the foam tiles and the vinyl floor. Had to take out the foam tiles to get the camper dried out. I expect that I will not put them back in. A pair of slippers will do.
Old 10-14-2018, 03:30 PM   #9
charlsara's Avatar
Trailer: 2014 Lil Snoozy
We discovered the foam tiles after we had a plumbing leak. We had just replaced the sheet vinyl in our Lil Snoozy with vinyl planks . The fresh water tank drain leaked. We fixed that and cleaned up all the water we saw. We didn’t think about water under the planks. After a couple of weeks we noticed mold on the lower trim molding. After tearing out the flooring. Replacing the moldings and killing the mold . I decided to paint the fiberglass floor with garage paint and not use a floor covering. We did that and it looked great but it was cold. The foam tiles work great and we take them out when the trailer is not used. They are also some of the cheapest flooring you can buy.
Old 10-14-2018, 03:38 PM   #10
Bernese Bunch's Avatar
Trailer: Lil Snoozy
Delaware
After one of our big floods at home in NJ, I used a loose lay floor from Karndean in my next house. The individual planks can be lifted and dried and then placed back in place. I'm in love with them and will order some for my Lil Snoozy when I finally get it...next year! I don't want issues if the dogs water bowl spills or I have a leak. I'm not very handy.
Bernese Bunch is offline   Reply With Quote
Old 10-14-2018, 03:48 PM   #11
charlsara's Avatar
When we replaced the molding I didn’t raise it over the tiles. They are very easy to take out and in.
Old 10-14-2018, 06:39 PM   #12
Good wool socks !!
Old 10-14-2018, 08:01 PM   #13
Gilda's Avatar
Trailer: 2011 Scamp 13'
When the tiles are installed can the Porta-Pottie door be opened? I suspect the thickness of the flooring will be too high to accommodate this low door.
I find that the original Scamp floor is a little too slick when I have our duffle bags on it in transit. There is nothing to keep them from skidding off the "step". I'm thinking that the non-skid interlocking flooring used for showers would work here.
The Gleeful Glamper
Gilda (Jill-da)
Old 10-14-2018, 10:04 PM   #14
Originally Posted by Gilda View Post
When the tiles are installed can the Porta-Pottie door be opened? I suspect the thickness of the flooring will be too high to accommodate this low door...
There was some discussion on FB about the gap at the bottom of that door. Seems like there is quite a bit of variation from the factory, so my guess is it depends. The door can be trimmed to accommodate any thickness flooring, though, so I don't see it as a big issue.
Vinyl floor over fiberglass floor? rdyn Modifications, Alterations and Updates 25 11-08-2017 08:04 AM
When the cold water is just too cold... TomandCallie Electrical | Charging, Systems, Solar and Generators 14 01-08-2017 10:02 PM
Advice on Allure Floor Install - Raising sub floor Tommy Gun Modifications, Alterations and Updates 4 10-12-2015 12:04 AM
Gelcoating Burro Floor to prolong floor life? not-very-clever Modifications, Alterations and Updates 12 11-23-2013 10:29 AM
How COLD is too COLD Gerry General Chat 11 02-05-2011 12:06 AM
