Cold weather toilet use - Fiberglass RV
Old 08-23-2009, 01:25 PM   #1
I was wondering if you could use the toilet if the trailer is winterized. I was thinking you could pour water in the bowl from a bottle and put antifreeze in the black water holding tank. You could then flush and the black water residue would not freeze with the anti freeze.
Any comments on whether this wold work or not
Ted Schmidt is offline   Reply With Quote
Old 08-23-2009, 02:53 PM   #2
Yes that will work and may not require the anti-freeze. In MOST of the molded lightweight fiberglass trailers, the blackwater tank is INSIDE the trailer... the toilet sits right on top of it. If the trailer is kept above freezing, the water in the tank won't freeze. Remember to keep the door open to the bathroom (and cupboards) if you don't want the contents to freeze.
Old 08-23-2009, 03:06 PM   #3
Joe Z's Avatar
Trailer: 16 ft Casita Spirit Deluxe
I just pour about 1/2 gallon of the pink rv antifreeze into the toilet to get it started and then everytime i use the commode i just pour a little more of the pink stuff into the bowl and flush. My camper fresh water tank is winterized and shut off for use..... just keep the pink stuff next to the toilet for when you need to use it. There's other ways to do it but this works for me.....
Joe
Joe and Linda
2013 Casita SD
Dodge Ram 4x4
Old 08-23-2009, 03:09 PM   #4
Donna,
Don't forget that the drain pipe for the black water tank goes out thru the floor and then to the side of the trailer.
Bill K
Old 08-23-2009, 03:18 PM   #5
Urine freezes at about -5 Celsius, 23 degrees Fahrenheit. Since it's the expanding of liquid that causes pipes to break, I would think any liquid that may freeze would have to room to expand up into the tank rather than straight out sideways.
RV antifreeze is pretty cheap, I can get it on sale for <$5 a gallon. In that case, better to be safe than sorry....
Old 08-23-2009, 10:07 PM   #6
Roy in TO's Avatar
One has to keep an eye open for those ICBM's
Cold Weather Camping Ted Schmidt Care and Feeding of Molded Fiberglass Trailers 6 08-23-2009 02:31 PM
Cold Weather Camping Dirk Lewis Care and Feeding of Molded Fiberglass Trailers 4 09-06-2008 01:21 PM
Cold Weather RV FAQ Aaron L General Chat 1 06-17-2008 08:40 PM
Cold weather condensation Sonny Care and Feeding of Molded Fiberglass Trailers 14 12-17-2006 06:11 PM
cold weather camping Andrew G. General Chat 0 01-01-1970 12:00 AM
