Compact/Hunter Owners:Screen Question - Fiberglass RV
Old 10-22-2009, 08:16 PM   #1
francene's Avatar
Trailer: 13 ft Compact II
The original door on my Compact II came with no screen. I bought a kit to make a screen; but looking at the door, I can't tell where the screen is supposed to fit.
If you have a screen on your door, where does it reside?
Thanks,
Fran
francene is offline   Reply With Quote
Old 10-22-2009, 09:11 PM   #2
Don H.'s Avatar
Trailer: Compact Hunter I
Thanks,
Fran
On mine, when both windows are closed, the screen rests above the bottom window, on the inside of the door. It's spring loaded, so you have to put the left side of the frame in first, and then push sideways to get the rest of the frame in. To expose the screen, you lower the outside window.
I guess you could put the screen on the outside, and slide the inside window up and down (?). Similarly, I suppose you could put the screen in the lower position, with the fixed window on top of it. Haven't tried these, so I can't say for sure...
Hope this is more helpful than confusing...
Don H. is offline   Reply With Quote
Old 10-23-2009, 02:58 PM   #3
Harry Young's Avatar
Post
Same as Don.
Harry
Old 10-24-2009, 12:16 AM   #4
francene's Avatar
Thanks Don and Harry! I will proceed with fitting a screen into the door. BTW, the door handle on mine is not working well. Have either of you replaced yours, and if so, was it tough to find that size? I'm having no luck finding a handle that small.
Best,
Fran
Old 10-24-2009, 08:56 AM   #5
Don H.'s Avatar
Best,
Fran
Francene,
By door handle, do you mean the non-locking lockset (the knob below the deadbolt)? By "small" do you mean the diameter of the knob, the thickness of the door, or the offset from the edge of the door frame, or the length of the knob shaft, or...?
I haven't replaced mine, but I went to look at it, and it looks like it was replaced at some point. It seems a little loose. If I can't tighten it, I may have to shim it with a piece of 1/8" plywood cut to the diameter of the trim piece. My door is only 1-1/4" thick, which is probably too thin for a regular household lock set. The knob is about 2" in diameter and I'd say it could be bigger with no problem.
I think you'll have better luck searching at RV parts stores than say Home Depot - seems like they should have hardware scaled down for camper construction. Also, there are a lot of RV salvage places, and I'd guess they'd have a large selection of used ones, and you could check all the important dimensions over the phone.
Edit: BTW, the brand name on both the deadbolt and knob set is Weiser. A search on "weiser locks" or "weiser lock parts" may turn up what you need.
Old 10-24-2009, 02:59 PM   #6
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
http://www.mobilehomedepotmi.com/parts_pag...oor_handles.htm
Mobile Home Parts
mszabo is online now   Reply With Quote
Hunter Compact II Owners Legacy Posts Care and Feeding of Molded Fiberglass Trailers 41 06-14-2016 10:08 AM
Compact/Compact Jr./Hunter, etc. owners POLL JenPB General Chat 22 03-17-2014 09:31 PM
14' Compact Jr./Hunter Kevin K Referrals: Molded Fiberglass Trailers 2 03-09-2010 08:57 AM
Compact/Compact Jr./Hunter class owners JenPB General Chat 21 06-05-2009 02:10 PM
Hunter 1 (Compact II ?) Legacy Posts Care and Feeding of Molded Fiberglass Trailers 24 05-13-2003 09:14 PM
