Old 02-20-2009, 08:02 PM   #1
Trailer: Compact Jr
I was lead to the Compact Jr. Brochure in the document center. (thank you) it says the unit shipped with a 5lb butane tank.. Is butane the same as propane?
My concern is if they are not - and the stove top is original - using butane - Is it safe or do I have to change something?
Thank you..
John
John Truitt is offline   Reply With Quote
Old 02-20-2009, 09:11 PM   #2
peterh's Avatar
Here's a run down on the different cooking gasses:
Methane -- also known as natural gas -- has one carbon atom and four hydrogen atoms.
Propane has three carbon atoms and eight hydrogen.
Butane has four carbon atoms and ten hydrogen.
Kerosene has around twelve carbon atoms and 26 hydrogen.
Each additional carbon atom in the fuel stores additional energy, so the larger, heavier fuels with more carbon atoms burn hotter and consume more oxygen when they burn.
Propane and butane are similar enough in size and energy that you can likely just tweak the air intakes on the burners a small amount to allow extra oxygen in to the air/fuel mix. A correctly adjusted burner should have a nice blue flame with no yellows, reds, or oranges in it. (These colors mean the fuel is not being burned completely, and the flame is producing poisonous carbon monoxide gas.)
Old 02-21-2009, 05:32 AM   #3
Trailer: Boler 13 ft
I remember back when I was backpacking in the 70's and 80's, I got a new Butane backpacking stove.
The rest of my hicking friends had propane or white gas.
Once the temps got down into the mid 20's F., My butane would not light.
The instructions said to "warm canister inside shirt to bring the temp above 32 degrees F."
This was on a small canister and I was wondering if on a larger bottle if the gas will not flow at colder temps.
Gerry
Old 02-21-2009, 11:12 AM   #4
Pete Dumbleton's Avatar
Butane is used to change the temperature characteristics of LP to compensate for seasonal ambient temperatures -- Hot air balloonists have to plan their flights and get the right mix for the expected temperatures (The LP seller will do the mix to the balloon pilot's specs).
Old 02-21-2009, 11:25 AM   #5
Trailer: Compact Jr
Thank you everyone. I did some more online searching. What I came across is that I have to watch which regulators I use. As the propane and butane are under different pressures.
Also butane will not flow under certain temperatures - that is correct. So I will double check the regulator and check the flame colors...
Thank you again..
Old 02-21-2009, 11:44 AM   #6
Tom Trostel's Avatar
I've used only propane with my Compact Jr. cooktop. No problems.
1980 Bigfoot 17' & 1973 Compact Jr
Old 02-26-2009, 09:06 PM   #7
Trailer: Compact Jr
Thank you all for your responses..
John
propane
Compact/Compact Jr./Hunter, etc. owners POLL JenPB General Chat 16 09-10-2011 06:46 PM
Ice box on propane gas Kevin K Problem Solving -- Owners Helping Owners 7 07-08-2009 06:29 PM
Compact/Compact Jr./Hunter class owners JenPB General Chat 21 06-05-2009 02:10 PM
propane cap carole sullivan Problem Solving -- Owners Helping Owners 5 05-11-2008 08:13 PM
WANTED A COMPACT JUNIOR OR COMPACT II IN VANCOUVER, B.C. Angela Mattice Wanted: Molded Fiberglass Travel Trailers 0 01-20-2007 12:19 AM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
