Compact Junior pop top gasket - Fiberglass RV
Old 10-04-2016, 12:04 PM   #1
Trailer: Compact Jr
Saskatchewan
Trying to find a replacement for the gasket as show in photo. U shaped with flat bottom. Any thoughts?
Janice Laliberte is offline   Reply With Quote
Old 10-04-2016, 01:47 PM   #2
Trailer: 1980 18' Sunrader Motorhome and 1971 Trailswest Campster
your photo did not get posted but I know what they are
They are also used as a gasket to mount a camper/canopy/shell onto a truck. So that is the place to source them from.
Pickup Truck Cap Camper Shell Lid Weather Seal Trim Tape 25ft Kit for 5.5ft bed | eBay
or
https://www.cargogear.com/OneItemInf...artnum=MPULTTS
Old 10-04-2016, 02:29 PM   #3
Trailer: Hunter Compact Jr.
USA
My '72 Compact Jr originally had Trim-Lok (not camper shell gasket) on both the edge of the lid, and the edge of the rim on the roof where the lid overlaps. You can find it on Amazon in rolls of 25' or more. I found this size to be a good replacement for the original Trim-Lok:
https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
Talia is offline   Reply With Quote
Old 10-04-2016, 02:34 PM   #4
Tom Trostel's Avatar
Trailer: 1980 Bigfoot 17 ft
2X what Talia said.
Old 10-04-2016, 02:38 PM   #5
USA
Also, I should add that I wasn't thrilled that it was black, but I found that Krylon Fusion spray paint for pvc/plastic works perfectly to make it any color you wish, so that if you're weird like me...you can color-coordinate your Trim-lok.
Just make sure you use the Fusion Primer, and then a couple light coats of the color you want *before* you snap it onto your roof edges.
Old 10-04-2016, 03:19 PM   #6
Trailer: Compact Jr
Saskatchewan
Thanks to all that posted. Not sure why photo was a no show. But advise has been sage and will be followed.
Old 10-05-2016, 10:53 AM   #7
Trailer: Compact Junior
Hi Janice
Here are a few shots that show the trim in place and a piece of trim similar to what is up there.
I can send you a snippet of this trim if you like to see if it fits. I think it also comes in a larger size. I could probably get a snippet of that too if you like.
I used this for the doorway of my sailboat. Very easy to put on. Boat supply places often have it, you might check out a West Marine if you have one in your area.
I bought it by the foot, if it came in a roll of 25' two rolls would probably be enough to do the top and the bottom.
john madill is offline   Reply With Quote
Old 10-05-2016, 11:03 AM   #8
West Marine and WalMart have it......
West Marine is very expensive.
WalMart has several styles and sizes at about 1/4th the price.
Here are a couple of links:
https://www.walmart.com/ip/TRIM-LOK-INC-750B2X1-32-25-Edge-Trim-Alum-Clip-0.2-In-W-25-Ft/41024600?action=product_interest&action_type=title &item_id=41024600&placement_id=irs-106-t1&strategy=SMT&visitor_id&category=&client_guid=8 938617b-ee49-47d1-8ef3-4871f81aaf8f&customer_id_enc&config_id=106&parent_ item_id=41088596&parent_anchor_item_id=41088596&gu id=f2bdf704-a7cc-4412-95d6-a2429bbc2853&bucket_id=irsbucketdefault&beacon_ver sion=1.0.1&findingMethod=p13n
http://www.westmarine.com/buy/taco-marine--flexible-trim--P024_724_001_008
Old 10-05-2016, 11:32 AM   #9
USA
Walmart is cheaper than West Marine, but I think Amazon is cheaper than Walmart if you've got Amazon Prime.
Old 10-05-2016, 11:36 AM   #10
Trailer: Compact Jr
Saskatchewan
Thanks for all the links and advice. Unfortunately Walmart US and Canada are two different operations. Our selection is much more limited. But do know some marine upholsterers so will give them a visit. Will keep everyone informed. By the by....four days of snow forecast here so all this will have to wait!
Old 10-05-2016, 12:16 PM   #11
Saskatchewan
Wink Sealer for CJ topper
Janice
Don't do it today!!!!!! In Watrous we have 4" of that dreaded white stuff. What do they say for us in Saskatchewan ??..........."It's a dry cold". They lied...it's a darn wet cold today!!
Our "CJ" is put away for the year. Tarped......Irish Spring soap inside to discourage any mice.......Up on blocks to get the tires off the ground.......Plastic garbage bags over the wheels to prevent sun damage to them. It's like putting a baby to bed!
As far as a seal is concerned.........we just used window tape with adhesive back (replace every second year???). More important is getting the 'hatch' to sit evenly down on the body. That means making sure the canvas and plastic windows are properly folded in.
Tell me again why we insist on living in Saskatchewan!!!!!!!!!!!!!
jish is offline   Reply With Quote
Old 10-05-2016, 02:59 PM   #12
Ebay usually has the best prices on edge trims and seals. Lots of Ebay stores for those items. That is where I have typically been able to find it in the quantities I need. You will find it in the automotive section of Ebay.
Old 10-05-2016, 07:19 PM   #13
Trailer: Compact Jr
Saskatchewan
Four days of snow forecast so no exterior work right now. Think I have sourced the moulding I need so a return to warmer weather I will get it done. Another question...oh there will be questions...is there no outlet on the compact junior to hook into regular electrical? I have a battery and all the cords but it seems there should be somewhere on the outside where we can plug in
Old 10-05-2016, 07:48 PM   #14
USA
On mine, the power access was under the sink, at the rear driver's side of the trailer. It does not go out through the side of the trailer, but rather through the floor in that rear corner. I don't know if they were all like that.
Compact Junior top fix raddar Problem Solving | Owners Helping Owners 23 05-18-2014 01:36 PM
Compact replacement washers for pop-top SouthwestOregon201 Problem Solving | Owners Helping Owners 1 04-11-2013 10:51 AM
FOUND! Pop-top Egg such as Compact II Bobbie Mayer Wanted: Molded Fiberglass Travel Trailers 3 03-16-2007 07:00 PM
Compact Jr. or II fabric pop-top piece Legacy Posts Problem Solving | Owners Helping Owners 4 07-14-2003 12:49 PM
