connecting multiple wires? - Fiberglass RV
Old 12-16-2016, 07:59 PM   #1
Trailer: UHAUL CT-13
Hi all,
I am rewiring my trailer lights and was wondering what people use to connect multiple (3 or more) wires. Mine has all those blue scotch locks to tap into wires, but I heard those are not very reliable. Twist locks, butt connectors, special techniques? Thanks.
Daniel the Texan is offline   Reply With Quote
Old 12-16-2016, 08:18 PM   #2
John in Michigan's Avatar
I use crimp splice connectors for all 12vdc wire splices. For exterior wire splices such as brake wire splices, I use weatherproof crimp splice connectors. My 1978 Trillium 4500 has all the original crimp splices and none have failed.
Old 12-16-2016, 08:49 PM   #3
If you decide to use crimp connections buy good ones such as T&B or 3M . The plating on the metal crimp sleeves and the insulation is of much higher quality than the cheap Chinese connectors . Also use a genuine T&B indentor style crimper.
They cost about $30 but they perform much better than the $5 ones sold at HD. I still have my original T&B crimper from when I started the trade in the late 60's . Nothing more frustrating than trying to find a bad splice once everything is covered up.
Old 12-16-2016, 08:58 PM   #4
http://www.bestboatwire.com/3-way-wi...rink-16-14-awg
Old 12-16-2016, 09:14 PM   #5
If you can not find the weatherproof ones, fill them with dielectris grease B 4 you crimp. It will keep the nasty stuff out.
Milspec - You only crimp once. Most people will crimp one more time and that weakens the first crimp.
I prefer the ratching crimp tool as it allows you to get the best crimp.
Ratcheting Crimping Tool
Old 12-16-2016, 09:25 PM   #6
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
I strip away part of the insulation to splice into a wire, then solder, and wrap with electrical tape. If terminating several wires to the battery, first go through a fuse block, then only one fused wire goes to the battery.
For the multiple negative/ground wires I go to a buss block, then one wire to the battery.
Dave & Paula
Old 12-16-2016, 10:10 PM   #7
junction box
Old 12-17-2016, 07:30 AM   #8
Carl V's Avatar
Trailer: 1981 Trillium 5500
Quebec
Depending on the wire size, these can accommodate 3 or 4 wires. Not weatherproof though.
To weatherproof a regular crimp connector, I slide a length of heat shrink over them, fill the ends with sealant like silicone, apply heat, the sealant will ooze out the ends and seal the connection.
Old 12-17-2016, 09:15 AM   #9
Dave & Paula
Some years ago, I used to work on radio, siren, and electrical systems in police cars and fire trucks. When they came into the shop with a problem, the majority of times it was a bad crimp. On my Casita, I go the solder route. The best electrical tape is the stuff that you stretch and then it fuses together in a watertight bond.
Terry G is offline   Reply With Quote
Old 12-17-2016, 10:54 AM   #10
Trailer: Trail Cruiser
Solder is the best. Then a good quality electrical tape.
Old 12-17-2016, 11:58 AM   #11
I don't use electrical tape if I have to and I only use 3M, if you want a water tight and strong connection the best is to solder the wires and use quality shrink tubeing. If you want high quality terminal connectors buy them from a heavy truck or equipment parts supplier generally they only handle the best.
larryf is offline   Reply With Quote
Old 12-17-2016, 02:08 PM   #12
Trailer: 2008 Casita 17 SD
I really like these little connectors. They make them for joining 2 wires, and up to several wires which can be "ganged" together. The nice thing about these is they clamp the wire, they don't cut into the wire like Scotch-Locks do.
https://www.amazon.com/Wago-222-412-.../dp/B003K0J4IQ
Old 12-17-2016, 02:14 PM   #13
Triker's Avatar
Trailer: 2016 Scamp 13'
solder
I solder and use heat shrink tubing when possible. If using electrical tape, don't stretch the last wrap.
Triker is offline   Reply With Quote
Old 12-17-2016, 02:44 PM   #14
mary and bob
I retentively purchased a box like yours at a low price from Walmart on line site.
There were quite allot of excellent posts on this subject. You cant go wrong following the advice on these posts.
Connecting all those wires. CD Smith Problem Solving | Owners Helping Owners 4 09-09-2013 03:27 PM
Lighting wires and sink pump wires in Burro Kemoldenhauer Problem Solving | Owners Helping Owners 3 08-14-2013 10:06 AM
No more multiple clicks Doug Mager Forum Admin, News & Announcements 9 09-20-2008 07:05 AM
Multiple trailers and irrational thoughts Karen T General Chat 20 08-13-2008 03:27 PM
Pulling Multiple Trailers Pete Dumbleton General Chat 9 12-30-2007 06:28 PM
