I'm curious about the LOAD terminals on my 30 amp controller.
I initially didn't plan to use the LOAD terminals, but reading the manual indicates I could run all my
Scamp load through the 30 amp LOAD output, which in turn would allow me to compare the amps used by each appliance to the amps provided by the 90 watt
solar panel. It would also provide low
battery voltage shutoff protection.
Right now, I have fused wiring from the panel to the controller, and fused wiring from the
battery to the controller. I also have the original
Scamp wiring that links the
battery, loads, converter, and tow vehicle power input together.
If I decide to use the LOAD terminals for all my
Scamp load wiring, do I need to split the converter and tow vehicle wiring off that circuit and hook those directly to their own battery circuit, or would I keep them connected to the current Scamp wiring and switch that wiring from the battery, to the LOAD terminals which would then also push the converter and tow vehicle charging through the LOAD terminals.
Thanks for any suggestions.
