Connectors for a DC circuit - Fiberglass RV
Old 09-12-2010, 01:01 PM   #1
Trailer: Bigfoot 13.5 ft
Hi everyone,
Now that the Texas heat is about to begin subsiding, I'm planning the next phase of my complete Lil Bigfoot renovation. When wiring several fixtures on one DC circuit, what type of connectors do you recommend to run the wires from the main cable (Anchor boat cable 14/2) to each fixture? Can you use a butt connector to splice the cable in or would it be better to use a 3-way connector similiar to those used in boats?
Thanks,
Carl
Carl G is offline   Reply With Quote
Old 09-12-2010, 03:28 PM   #2
Joe MacDonald's Avatar
I usually solder and heat shrink mine, but it should be whatever works good for you.
If using crimp style connectors, make sure you get a good crimp connection.
Cheap crimpers usually don't work that well.
Joe
Old 09-12-2010, 03:55 PM   #3
Joe
I absolutely agree with Joe. Cheap tools are awful. You usually have to work just as hard with a crappy tool as a good one (whatever tool) and often have to do the job over because of it. Bite the bullet and buy a good crimping tool AND a good rivet tool. You won't regret it. Skimp on the hammer....
120 volt wire connectors Carl G Problem Solving | Owners Helping Owners 7 05-28-2010 10:45 AM
PowerPole connectors for Solar Wiring OK? Pamela S. Problem Solving | Owners Helping Owners 7 01-23-2010 04:10 PM
End of the Saga of the circuit board & circuit breaker mishaps Adrian W Problem Solving | Owners Helping Owners 1 07-22-2008 05:11 PM
Posi-Lock Connectors david duboe Modifications, Alterations and Updates 2 02-16-2008 11:23 AM
circuit breaker Ken & Sherry B. Problem Solving | Owners Helping Owners 11 10-16-2007 08:18 PM
