Old 10-08-2008, 03:00 PM   #1
Trailer: 2001 Scamp 16 ft. & 1970 Campster
I am looking for a topper or cover for the 2 burner stove top .I don`t want to use the stove but need to cover it to make more counter space. Have tried several sizes of pans-nothing big enough. I can make one from scratch but thought if I could find one or something that would fit-19" x 14" in size it would be quicker and easier.
Has anyone bought such an item?
Thanks
rich
Ricky 4 is offline   Reply With Quote
Old 10-08-2008, 03:06 PM   #2
Scott S.'s Avatar
Trailer: 1975 Surfside TM14 (front kitchen)
Manitoba
Send a message via MSN to Scott S. Send a message via Yahoo to Scott S.
most restaurant supply place carry a variety of dif. sized cutting boards? just a thought. I work for a metal manufacturer and although we don't do custom stuff I know it's a pretty simple thing to build in stainless. there may be someone that works with restaurant kitchens that can steer you in the right direction. might be costly... but you'll only do it once.
Scott S. is offline   Reply With Quote
Old 10-08-2008, 03:26 PM   #3
Al V's Avatar
Trailer: 2005 17 ft Casita Freedom Deluxe
Send a message via Yahoo to Al V
Did you check with casita. stove top covers are an option they offer
Al V is offline   Reply With Quote
Old 10-08-2008, 03:49 PM   #4
Daniel V.'s Avatar
Trailer: '74 Trillium 1300
I have made one out of cedar, which doubles up as a food tray when you take it off and flip it. It fits nice and snug, and makes a solid surface to put things on. I can take pics if interested.
Daniel V. is offline   Reply With Quote
Old 10-08-2008, 03:50 PM   #5
Howdy, you could make a simple shallow box out of maple to fit over your stove and use it as a cutting board if necessary and flipped over use as a tray for serving....see my web shots picture site for the one in my Boler...Benny
Old 10-08-2008, 03:52 PM   #6
Shucks you beat me by a minute,LOL...Benny
Old 10-08-2008, 04:16 PM   #7
CindyL's Avatar
Trailer: 16 ft U-Haul VT
Illinois
Walmart sells different sized cutting boards. I keep one in the closet when I want more space and am not using the stove. It fits over the burners. Since we got the Coleman stove, we rarely use the stove inside.
CindyL
CindyL is offline   Reply With Quote
Old 10-08-2008, 04:40 PM   #8
Roger C H's Avatar
Talking
Thanks
Have you looked at cookie sheets or shallow baking pans?
Old 10-08-2008, 04:56 PM   #9
Trailer: 2008 Scamp 16 ft
I use a small white cutting board from WalMart, it fits nicely over the 2-burner stove. Great for added counter space! I have a piece of non-skid shelf liner under it, and it stays in place while traveling.
Diane G is offline   Reply With Quote
Old 10-08-2008, 08:59 PM   #10
Sandra Lair's Avatar
Trailer: 1982 Scamp 13 ft
Another version of the cutting board idea--I drilled holes in the bottom of the cutting board near each corner & glued short pieces of dowel into the holes. The "legs" were spaced so that they held the board in place snugly .
Sandra
Sandra Lair is offline   Reply With Quote
Old 10-09-2008, 05:38 AM   #11
I ordered one from Casita for my previous trailer. I don't remember the price, but it was reasonable with shipping. It was easy to install.
Morgan is offline   Reply With Quote
Old 10-11-2008, 07:12 PM   #12
theresa p's Avatar
New Brunswick
Post
here's the best solution I've seen ----our friend david built, in mere minutes..a fantastic stove cover simply and cheaply. he measured the size needed, cut a piece of leftover plywood and simply screwed on each corner one doorstop!
the rubber ends of the doorstoppers made excellent feet, unscrew readily if needed and it just stands up behind the stove when in use! ingenious, quick and easy....my kind of project.
way to go, david...
Old 10-11-2008, 09:39 PM   #13
way to go, david...
Wish all projects could be this easy-what a simple answer to my problem. I am going to use a wooden cutting board. Will try to get pictures. THANKS MUCH
rich
Old 10-21-2008, 05:50 PM   #14
Karen B.'s Avatar
Trailer: 2002 13 ft Scamp
Nebraska
Actually, that's what I've got in my 13-foot Scamp, a half-sheet pan turned upside down from a restaurant supply store. It fits perfectly (though I did use a couple pieces of duct tape to keep it in place during transit). I put a piece of non-skid stuff on top of it and that's where I intend to put my microwave (when I get one). I took some of the same non-skid stuff and taped it to the bottom of a large wooden cutting board that had warped too much for me to use it, and I put that over my sink. (And that doesn't move at all, but if I want to get to the sink, it's easy enough just to lift it up.) So now I've got great useable counterspace.
Karen
Karen B. is offline   Reply With Quote
Need a Cover Emmitt G. Care and Feeding of Molded Fiberglass Trailers 6 03-24-2010 02:21 PM
Vent Cover and Power Outlet Cover Todd Sleeman Classified Archives 0 11-30-2008 05:29 PM
Found Perfect Cooktop! Filbert V. Modifications, Alterations and Updates 6 04-18-2007 08:50 PM
U-Haul cooktop replacement Jeanne and Steve Problem Solving -- Owners Helping Owners 15 05-23-2006 04:16 PM
To cover or not to cover, that is my question?! Legacy Posts Care and Feeding of Molded Fiberglass Trailers 33 06-05-2003 07:49 AM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
