copper pipe identification - Fiberglass RV
Old 09-05-2012, 09:54 AM   #1
Trailer: boler 13
Manitoba
Good day everyone-first post. I have a '76 Boler and am about to start on a rehab process after i have gotten sufficient knowledge from this great forum. To start with, the above picture shows a copper tube in front of other pipes going to the water tank below the floor level. In the other direction, I believe it goes through the floor to the inside of the left rear wheel and then forms a tee with other propane tubes below the furnace. It must be for propane, but would this be for some sort of water heater? I would not think that there would be accomodation for one underneath.
Secondly, you can see three wires, two black and one red. Currently I have no battery setup, but what were these originally for?
Thanks again, Barnaby
barnaby is offline   Reply With Quote
Old 09-05-2012, 07:14 PM   #2
Hi Barnaby, welcome to FiberglassRV
I'm going to leave your question to the experts, but wanted to take the time to say we're glad you're here
Old 09-06-2012, 12:22 PM   #3
Trailer: boler 13
Manitoba
Thank you Donna for the kind reception. I did some further investigation and soon discovered that the copper propane tube was in fact the feed for the furance-a bit of a Homer moment, when a very dim bulb managed to illuminate.
The three wires I referred to under the seat originate close to the tongue in the front here:
Uploaded with ImageShack.us
They were for a front battery install, I assume, I just need to know what they would have fed under the left bench. Thanks again.
Uh Oh---should we have left the pipe in??? Vickie B. Problem Solving | Owners Helping Owners 15 04-11-2011 02:33 PM
new fangled plumbing pipe Scott S. Plumbing | Systems and Fixtures 8 10-08-2008 11:10 AM
Plug Identification Christi W Electrical | Charging, Systems, Solar and Generators 7 11-16-2006 07:06 PM
You need pipe cleaners Legacy Posts Care and Feeding of Molded Fiberglass Trailers 1 09-23-2002 07:03 AM
