Correct battery information for monitor - Fiberglass RV
Old 01-31-2011, 10:08 AM   #1
DannyH's Avatar
Trailer: 1976 Scamp 13 ft
In setting up my battery monitor, I have a couple of questions. I have a Deka marine master DP27. It says CCA=650, 23 amp 175 min. The battery monitor wants to know.
1. "Charged" set point voltage. 10 to 65.0 volts (preset at 28.6)
2. "Charged" set point amps. 1 to 100 (preset to off)
3. "Battery capacity amp hours 10 to 10000 (preset at 400)
On #1; I don't see anything on voltage.
On #2; Would my set point amps be 23?
On #3; I'm confused because with 175 min on battery, wouldn't this be 2.9 amp hours, which is less than the 10 min?
Thanks
DannyH is offline   Reply With Quote
Old 01-31-2011, 10:27 AM   #2
Greg H's Avatar
Trailer: 72 Boler American
Indiana
that sounds like a starting battery.
Old 01-31-2011, 10:56 AM   #3
DannyH's Avatar
I purchased it at Curtis trailers. They said that this is what is put in all their trailers.
Old 01-31-2011, 11:24 AM   #4
Greg H's Avatar
Indiana
Danny, I just looked at my battery it's a dual purpose marine battery from auto zone. It says 1000 cranking amps wich I didn't realize 115 amp hrs, that I did know, the amp thing is a math problem that I do not understand. My charger has settings of 2,6,10 amps I use the 6 amp setting and everything seems to be okay.
Old 01-31-2011, 12:25 PM   #5
DannyH's Avatar
Thanks for the reply Greg. I checked and your correct that it's a starter battery. I talked with Curtis trailer today and they said that's what is typically sold unless the person wants a gel battery.
Old 01-31-2011, 12:55 PM   #6
DannyH's Avatar
I did more reading on the battery specs and it says to charge the battery to 14.2v to "overcome internal pressure during charging". I think this must be the "Charged " setpoint voltage. I'm still trying to find information on amp minutes to amp-hours. I did find that it based on 20 hour draw on the battery. If I figure my battery at 23 amp for 175 minutes and convert that to 1 hours it comes to 67 amps. So 67 divided by 20 hours = 3.3542 amp hours. Anyone know if this is correct?
Old 01-31-2011, 01:02 PM   #7
DannyH's Avatar
Called Deka and found the information. Had a brain freeze as I should have done that first.
battery
Equus Battery Monitor Paul Braun Problem Solving | Owners Helping Owners 0 08-11-2010 08:06 PM
simple battery monitor Scott S. Problem Solving | Owners Helping Owners 6 10-02-2008 05:38 AM
Using Xantrex Battery Monitor kevin61 Problem Solving | Owners Helping Owners 0 07-13-2008 02:42 PM
Dirt Cheap Battery Monitor AZCharlie Care and Feeding of Molded Fiberglass Trailers 2 03-24-2007 11:52 PM
Battery Monitor Toodie Care and Feeding of Molded Fiberglass Trailers 17 08-02-2006 04:06 PM
