crack on shell under door hinge - Fiberglass RV
Old 11-14-2012, 11:03 PM   #1
Idaho
When I replaced the nuts, bolts, and brass ball on my door hinges, I noticed that the shell of my Boler is cracked underneath the hinge. The bolt is holding for now. It's a little wobbly and I'd like to fix it before it completely falls apart. I'll add some sort of metal or wood strip inside the door to give it some structure. But how should I fix the crack? I can't seem to find anybody with the same problem. It always seems to be the hinge on the door itself that people fill with something like Tech Steel. What's the best way to fix the crack and beef up the area so it doesn't happen again?
Thanks.
brownrecluse is offline   Reply With Quote
Old 11-15-2012, 02:02 PM   #2
Raz
Raz's Avatar
Vermont
Hi Jeff. A picture would help. Knowing exactly what you're up against will bring more suggestions. Raz
Old 11-15-2012, 02:49 PM   #3
Idaho
Ok. I get it back today or tomorrow from getting my new furnace installed. So I'll grab a picture to help. Thanks.
Door hinge options kentj Problem Solving | Owners Helping Owners 10 04-06-2015 02:34 PM
Boler door hinge repair kit and fridge access door John Jesse Problem Solving | Owners Helping Owners 5 05-27-2011 12:32 PM
Door hinge/molding RicK M Classified Archives 0 10-07-2006 10:25 PM
Replacement door hinge Legacy Posts Problem Solving | Owners Helping Owners 7 05-27-2003 04:22 PM
Door hinge/molding Wanted: Molded Fiberglass Travel Trailers 0 12-31-1969 07:00 PM
