I need to add some interior walls / insulation to the Perris. Before I do that, however, I want to rewire the most of the trailer. Currently there are many many butt-connectors holding the wiring together and I don't want to bury that behind the walls. Too many connections that can go wrong down the road.
So going off the current wiring that is in place, and using
this Schematic from the document page here, I created this electrical-ladder plan.( I do have some elec experience.)
Any of you
electrical wizards wanna look it over though? See anything wrong?
I want to add a couple of extra running
lights, I only show a few here but there will be more wired parrallel.
I may also add another leg of 120 V wire to the roof vent, I plan on putting a bigger AC/fan (maybe heater?) in the roof vent hole. (not shown here) So I can operate that when we have a hook-up. I'll leave the wires un-connected obviouslyfor now.
All
electrical components seem to be original to the 82 Perris, A lot of the brake / run
light wiring has been "fixed," hence all the brittle butt-connectors.
I am thinking 12 and 14 G stranded copper wires.
The car already has a 6-pin male connector on the rear bumper. The wiring is more of a 4-pin currently. I will run an extra wire from the trailer-to-car connector to daylight under the cabinet with the rest of the
electrical for a future component, should I need one in the future.
Right now I have about 4 various 4 & 6 pin adapters between the car and trailer. Messy for sure. I will of course clean that up to just the one 6-pin connection.
Any advice or changes you all see??
Thanks again for your help!!
