CT-13 cushion pattern needed - Fiberglass RV
Old 09-14-2011, 11:10 AM   #1
Trailer: U-Haul
Hi, every one, I am a current owner and in the rebuilding stage of a CT-13 and am in need if a set of seat cushion patterns. If any one knows where I can find them I would be most thankful.......Thanks ....Hutt
Hutt is offline   Reply With Quote
Old 09-15-2011, 04:46 AM   #2
Bud Kennedy's Avatar
Trailer: 1984 U-Haul / 02 Mazda pick up
We have a ct-13 and would be willing to trace the outline of our cushions on butcher paper for you.
E-mail gonzo_ii@yahoo.com
Bud Kennedy is offline   Reply With Quote
Old 09-15-2011, 06:56 PM   #3
Trailer: U-Haul
E-mail sent
Old 09-15-2011, 07:30 PM   #4
I love it when a plan comes together Good going Bud and Judy!
Old 01-03-2014, 04:35 PM   #5
Trailer: UHaul
Massachusetts
This is a very old thread, but I wonder if anyone ever kept the measurements? I am in the midst of tracing out what I think I want but it would be nice to see a pattern. I inherited a nice huge cushion. I think it is the cushion from the top bunk. It is a little too big for the front space, and I want to make 3 cushions so that it is easier to get things out from storage.
Sharon D is offline   Reply With Quote
Old 01-03-2014, 08:17 PM   #6
Bud hasn't been around for quite a while: Last Activity: 04-21-2012 11:36 AM But Hutt was here Last Activity: 06-07-2013 02:10 PM
Hope for the best!
Old 01-03-2014, 09:38 PM   #7
Sharon; we have two different size front full width cushions. One is wider, (front to back) than the other. The upper bunk was missing in our Uhaul so I'm not sure of what their original placement was, but we used the wide one as the bottom, and the narrow one as the back, for a front couch. Now we have a captains chair from a Casita mounted in the corner inside the door, and one of the curved cushions that would have been in the rear, the one that's about 3 or 4 feet long, as the bottom, and a rectangular one that's about 2 feet long as the back to finish off the front as a couch. So you could use those cushions maybe as patterns?
Old 01-03-2014, 09:52 PM   #8
Pam Garlow's Avatar
Trailer: U-Haul 1985
In the original configuration the larger one was the upper bunk. when the bunk was folded down, then you would put the much narrower (depth) cushion in front of it to make a very uncomfortable, shallow bench. It was pretty useless.
So I removed the bunk and gave the supports away to another UH owner. I took the larger top bunk cushion foam out, and shaved it smaller to better fit the lower seat area. then I just put it back into the cover.
http://www.fiberglassrv.com/forums/f...ump-58138.html
Old 01-03-2014, 10:03 PM   #9
Our "bump" bunk support was already gone when we got the trailer. A small shelf had been built on the wood support, but it would poke me in the back when sitting there. I had to narrow all that down, cover it all with carpet, and used a piece of 1" aluminum angle as the shelf edge. Result is a narrow storage area for small items, keys, flashlight, and most important my "hillbilly backscratcher"
Old 01-04-2014, 10:42 AM   #10
Trailer: 1984 UHaul CT13
Sharon,
I have made the front "sofa" into three cushions for the same reason as you, to access storage. If that is the measurements you want send me a PM and I'll get them out of the closet and measure them for you.
Patti
keekers is offline   Reply With Quote
Old 01-04-2014, 11:55 AM   #11
Trailer: UHaul
Massachusetts
I'm measuring and cutting paper this afternoon. I'll post my measurements to the group. The beautiful cushion I inherited has the following note on the foam: 3: 24 1/4 x 74 1/2 x 4.
Help... Looking for a pattern for 16 SD Casita Shelf Legacy Posts Problem Solving | Owners Helping Owners 4 05-16-2019 12:26 PM
What is the bolt pattern on a Casita? BAMA & Pachyderm Posse Care and Feeding of Molded Fiberglass Trailers 1 01-11-2010 05:15 AM
I want to make overhead cabinets, anyone have a pattern? Art OC Problem Solving | Owners Helping Owners 8 04-12-2008 09:44 AM
5'X8' pattern rug! Ryan Kennelly Modifications, Alterations and Updates 10 05-05-2006 10:12 PM
Pattern for a 16' Casita Bed... Legacy Posts Problem Solving | Owners Helping Owners 9 02-25-2003 09:15 AM
