Curve of entrance door - Fiberglass RV
Old 02-05-2019, 09:57 PM   #1
I have a 1978 Boler 1700. I noticed the other day that the curve is coming out of the entrance door. Has anyone had this issue and had success in dealing with this problem? If so how did you address it?
Dennis Hannaburg is offline   Reply With Quote
Old 02-05-2019, 10:35 PM   #2
Trailer: Casita 16ft.
Your problem is most likely is due to the breakdown of the wood framework that is glassed into the door the door. It is especially weak (at least on my mid 80's Casita) at the center where the door latch mechanism is mounted.
On my trailer a PO added a lightweight cable anchored near the top and bottom of the door with a turnbuckle placed in the center. The door curve can be adjusted by turning the turnbuckle in or out. It's a little hokie but the set up works fair but not perfect.
The best way to correct the problem is to take out the old rotten wood and replacing it with new. This will require some fiberglass work. That is what I plan to do on my trailer eventually. There is a guy named Eric who rebuilt the door frame on his older Casita. He posted a lot of pictures. Here is a link to his post.
http://www.fiberglassrv.com/forums/f...6-a-81327.html
I think he had to do the job over a second time to get it right so make sure read all of the way through his posting until you to get the second repair.
Nor Cal Mike is offline   Reply With Quote
Old 02-06-2019, 11:58 AM   #3
Trailer: G30 Elite Class C
r you could re-frame the door way so that it does not have the curve any longer, That curve will cause problems from day 1.
Stude
stude is offline   Reply With Quote
Old 02-06-2019, 03:11 PM   #4
Massachusetts
Recurve the curve
I did a total rebuild, but the process to recurve the door is similar. You may not have the rot that I did, and may only need to kurf cut the inner core wood. and apply the epoxy.
See my blog for details. My Scamp Fiberglass Egg Camper: Repairing a Scamp camper door.
GQ
eggscamper.blogspot.com/
Garycamper is offline   Reply With Quote
Old 03-03-2019, 08:22 PM   #5
Roy in TO's Avatar
It is possible your door is just fine. Have a look at how it is constructed or even post a picture of the interior surface.
Chances are, you may have what some call body bulge. Totally different fix.
My suggestion. Do your research. Good and bad answers / opinions abound here.
How to restore the curve in Scamp door PilotPica Modifications, Alterations and Updates 1 11-23-2017 03:20 PM
Extra Trailer entrance door step Mike Price Care and Feeding of Molded Fiberglass Trailers 19 02-25-2011 05:54 PM
Scamp Entry Door Curve? scott p Problem Solving | Owners Helping Owners 8 06-01-2010 01:41 PM
Entrance/Main Door FredericL Problem Solving | Owners Helping Owners 2 07-08-2008 08:55 PM
casita entrance door hinges (new) gerald rush Classified Archives 0 04-13-2008 08:06 PM
» Trailer Showcase
Ventura
Ray in BC
Nubbs
spue
