Cut 1 1/4" Hole for DC Receptacle - Fiberglass RV
Old 05-27-2014, 10:59 AM   #1
Trailer: ParkLiner
Virginia
I've never cut or drilled fiberglass before. I need to cut a 1 1/4" hole in the bottom of a cabinet so I can install a 12v receptacle.
Can I use a hole saw for wood? Should I tape the fiberglass? Drill from inside cabinet or from below cabinet?
Any thing else I need to know?
Thanks
Huck is online now   Reply With Quote
Old 05-27-2014, 11:05 AM   #2
You are correct on all counts. Hole saw with a pilot drill in the middle and if the fiberglass is visible, put masking tape over it so it does not chip. You may want to wear a breathing mask to keep the glass out of your lungs.
Old 05-27-2014, 11:06 AM   #3
I just used a Drill hole saw attachment when I had to put a hole into the bottom of my cabinet. I taped it before doing.
Old 05-27-2014, 11:06 AM   #4
Name: Kevin & Lisa
Trailer: Scamp16
Ohio
I just drilled through the side for the shore cord with a 3" bi-metal hole saw from lowes. If you can start drilling from in the cabinet to 'get the groove started'
Then drill from the bottom up.. this helps to reduce tear out when you break through. Also pushing easy. And wear gloves and long sleeves... Just drilling one hole got the fiberglass dust on my arms and took scrubbing with a pot scrubber to stop the itching
summer scamp is offline   Reply With Quote
Old 05-27-2014, 11:16 AM   #5
Trailer: ParkLiner
Virginia
Thanks. Off to buy a new hole saw.
Old 05-27-2014, 11:50 AM   #6
Use a shop vac to suck up the dust as you cut saves a big ichy mess.
Old 05-27-2014, 11:54 AM   #7
Run the hole saw in reverse. Less chance of the bit grabbing and doing damage
3 pin male Shore power receptacle frankcfx Modifications, Alterations and Updates 7 05-08-2014 11:50 AM
can we have an undercounter garbage receptacle Peggy Modifications, Alterations and Updates 3 08-25-2013 10:15 AM
Blowing fuses and receptacle question.. Bluebamboo Electrical | Charging, Systems, Solar and Generators 19 05-29-2013 03:52 PM
Aux 12VDC receptacle ShirleyA Electrical | Charging, Systems, Solar and Generators 8 08-03-2012 07:47 AM
Adding a Hitch receptacle to a Scamp bumper? efawcett Towing, Hitching, Axles and Running Gear 13 10-22-2007 09:21 AM
