Cuttin quarter round for boler floor trim - Page 2 - Fiberglass RV
Old 06-01-2009, 06:51 PM   #15
Pat C's Avatar
Trailer: 1981 Boler 13 ft / 2005 Dodge Caravan
So here goes my Monday reply. On an outside corner lay one molding along one wall and the other along the other wall so that they are overlapping at the corner. Run a pencil line down both sides of the both moldings marking the opposing moulding. Draw the diagonal line on each moulding starting at the inside corner and then cut along the diagonal line.
On an inside corner again run both mouldings into the corner and overlap making sure the inside of the moulding is tight against the corner. If the angle of the wall is less than 90 degrees then you will have to trim the end of the moulding back a little so it will fit tight in the corner. Mark both mouldings where they overlap on the corner. Now draw a line from the inside corner of the moulding to the pencil mark. This should be a diagonal line. Then cut along the diagonal line.
This technique will only work with low mouldings, no more than about 1 inch high. Since you are using quarter round this shouldn't be a problem.
Thanks so much.Sounds like a plan I can follow.Going to try it tomorrow.Got me a contractors protractor and if I find this won't work I will go with planB.
Pat C is offline   Reply With Quote
boler
Boler Door and front window trim Lori Appleyard Problem Solving | Owners Helping Owners 12 03-21-2012 10:19 AM
New floor in 1977 Boler Neil W' Problem Solving | Owners Helping Owners 2 07-15-2009 07:39 AM
Boler floor jj giger Problem Solving | Owners Helping Owners 2 06-21-2007 08:57 PM
'74 Boler floor help? julian Care and Feeding of Molded Fiberglass Trailers 3 09-20-2006 01:20 PM
Boler 79 Floor Plan General Chat 0 12-31-1969 07:00 PM
