cutting table bench side opening - Fiberglass RV
Old 04-17-2009, 12:36 PM   #1
johnsoba's Avatar
Trailer: 82 Scamp 13 ft
i have a 1980s 10 ft. scamp. the table converts into a bed. this conversion is a pain so we leave it in bed mode. the large space under the bench on the sink side can only be accessed on the top. with the bed down that means no access without lifting up the entire bed(very heavy!!). so i want to cut an acess hole in the flat corner(not the part under the bed) so i can access some of that space easily. is this stupid ? will i compromize the the support of the bed? please help and any other hints about how to get more storage space in my beloved but tiny home on wheels. thank you ann
ps i know some of you love the little moving things ,but they are a nightmare for ADD people like me. sorry to spoil your fun, maybe some that don't move? that would still be cute but not drive me crazy while i try to read. thanks
johnsoba is offline   Reply With Quote
Old 04-17-2009, 12:43 PM   #2
Steve Hilby's Avatar
Trailer: Compact Jr
Seems to me I saw a thread on these forums where someone had done exactly what you're proposing, and had made a little door for the opening.
Steve Hilby is offline   Reply With Quote
Old 04-17-2009, 01:30 PM   #3
peterh's Avatar
You can cut access doors in the bench, just make sure you cut only in the flat parts of the bench (not at any of the angles) where there is a single, thin layer of fiberglass without reinforcing members and leave a 1-1/4" rim of fiberglass around the top and sides of the cut. Once the opening has been made epoxy in some 1" wide strips of 3/4" plywood to reinforce the top and sides.
The problem with this approach is you either wind up with a really small door for accessing a big, big space, so you might try an alternate approach: putting a hatch in the outside wall.
Old 04-17-2009, 04:03 PM   #4
Larry&Carrie's Avatar
Trailer: 1983 13 ft Scamp
Send a message via MSN to Larry&Carrie
Talking
That's on my list of updates to do this Spring..... (both sides I might add...) What I have planned to do is glue/bond a wood frame around the inside of the opening I cut-- mainly to give a place to mount the hinges and catch to, but also to add a little structure integrey... It will be a small access, but little things like shoes, disposable prone bottles, etc will easily pass thru. (sleeping bags, blankets will too, if you leave them unrolled....) Larry
Larry&Carrie is offline   Reply With Quote
Old 04-20-2009, 08:50 PM   #5
johnsoba's Avatar
Excellent ideas. Thanks!!
Ann
Side Table *Photos* Flygal Modifications, Alterations and Updates 20 10-27-2009 07:39 AM
Cutting into icebox opening karen lm Problem Solving | Owners Helping Owners 2 09-17-2009 02:46 PM
TAKEN - Casita 17'SD side table top Paul Bostick Classified Archives 3 11-04-2007 04:44 PM
side table james kent Modifications, Alterations and Updates 4 04-05-2006 01:54 PM
Cutting into icebox opening Gail S. Towing, Hitching, Axles and Running Gear 0 01-01-1970 12:00 AM
