Dead Battery after 2.5 hours towing Casita with fridge on DC - Page 3 - Fiberglass RV
Old 05-15-2019, 01:08 PM   #29
Trailer: Currently Shopping for a Casita
Nevada
If you worry about running the fridge on propane maybe a device like the GasStop shut off valve would help alleviate some of your fears. It's meant to shut off the gas in case of a major leak. Just a thought.
Brian1724 is offline   Reply With Quote
Old 05-15-2019, 01:16 PM   #30
Trailer: Miti Lite 1987
Dead battery
Plug connectors wear out. The pinch contacts weaken from use and temperature swings to the point they develop high resistance to current, and also can trip breakers and blow fuses. You might check the "grippiness" of the terminal connectors. In houses, the wall recepticle is worn out whe plugs are easily disconnected, and if they fall out of the receptacle it becomes a serious fire issue
Peder_y2k is offline   Reply With Quote
Old 05-15-2019, 01:31 PM   #31
I believe all recent propane cylinders have a built in valve to shut off flow in the event of a major leak. That's why you need to open your propane tank slowly in order to prevent triggering that valve.
Old 05-15-2019, 01:53 PM   #32
Nevada
If you have EFV (Excess Flow Valve) connecter to the rv it should cut off 90 to 95% but does not completely shut off gas flow.
I'm not endorsing this product btw, because I don't own one, but if I was apprehensive about driving with propane on I'd want to know I had a valve that would shut off completely in case of a hose leak.
Old 05-15-2019, 02:38 PM   #33
Trailer: 1999 Casita 17' SD
Ohio
They are called excess flow device" and they are already in all of the "pig tails" that have a green knob with Acme threads. Go to this site and scroll down to "Pig tail Problems" and verify what I'm saying.
LP Snafus You Can Fix - RV Life
Old 05-19-2019, 12:04 PM   #34
Trailer: Designing and building
We have rigged our TV and teardrop with a seven-blade connector, and included underway charging. With the length of the run from TV to trailer battery, we used the voltage drop inherent in the 10 ga. wiring as a current limiting device - at full current there's a 3V drop, which in turn limits the current to well below the peak. The practical upshot is that we can run a midsize Waeco-Dometic compressor cooler all the time, lighting as needed, and exhaust fans at night, all off a 55Ah battery, all over the US. Solar or shore power when we are camped.
We will be redesigning this for our upcoming FG fiver - mostly relying on a huge solar install, but also a 200A alternator as emergency power.
Thomcat316 is offline   Reply With Quote
Old 05-20-2019, 08:00 PM   #35
Radar1's Avatar
Name: Dave (and/or John)
I've always wondered how much current the TV alternator will actually send to the trailer battery once the TV battery is fully charged? It would seem that to prevent overcharging the TV battery, the alternator circuitry would cut back on charging voltage to protect the TV battery. If that happens, then the trailer battery would not be getting much charging at all, and with the high demand of the fridge, would simply discharge itself.
I have two different type batteries in my TV (12 volt AGM) and trailer (12 volt golf cart battery) and everything I have read seems to indicate that when you charge two batteries in parallel (which is basically what you're doing while towing) they should be very similar in type, age, and amperage, otherwise the weaker battery never gets fully charged.
Fortunately I don't have the fridge problem as our particular Scamp only has the AC or propane option.
Thoughts?
John-Dave and Marilyn
Sharpsburg, GA
04 Dodge Dakota V-8 and 17 Dodge Durango V-6
radar1-scamping.blogspot.com
Old 05-21-2019, 04:18 AM   #36
The only thought I have (before coffee) is that AGM and wet cells have different charge voltage requirements. Don't remember which needs more, at the moment.
Old 05-21-2019, 07:31 AM   #37
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
You are talking about "current" measured as amperage. That is similar to flow in a water pipe.
The level of charge in the batteries is measured as voltage, like the pressure in a water pipe. Water pressure is highest when there is zero flow.
Likewise, when batteries reach full charge (13 to 14 volts) the voltage regulator at the alternator reduces the current output to a mere trickle, just enough to operate any devices that are "on"
With two batteries connected in parallel they will charge up until both reach a full charge. It is when batteries are in series that they can get unbalanced.
Old 05-21-2019, 03:56 PM   #38
Dan Meyer's Avatar
How much current does your 'fridge pull on 12 volts? I don't have a 12 volt option on my 'fridge, but it uses 1.3 amps at 120 volts, or 150 watts. 150 watts at 13.8 volts is about 11 amps. Unless the charge line is adequately sized and both the charge line and ground connection in the trailer electrical connection to the tow vehicle are in perfect condition, you will not be able to move 11 amps from your tow into the trailer.
Also, how old is your battery? If it is more than 2-3 years old chances are it has less than half of its rated capacity. The group 24 supplied with most of our trailers at the factory is 80 amp-hours when new. It is not beyond the realm of possibility that your battery is simply aged and has an effective capacity of only 30 or 40 amp hours. When you are using 11 amps to run the 'fridge, 40 amp hours won't last very long. 4 hours would be pushing the limits.
--Dan Meyer
Old 05-21-2019, 08:36 PM   #39
DougOlson's Avatar
I have a 2-way frig, propane & 120v, but recently arranged to run it on 120v via inverter power while towing. The frig draws about 170 watts and the most power available through the 7 pin plug is about 120 watts (10 amps). So then I ran another 10 gauge wire from the TV battery to trailer and that solved the shortage, now all power for frig comes from TV while engine is running.
DougOlson is offline   Reply With Quote
Old 05-21-2019, 10:21 PM   #40
Steve Outlaw's Avatar
Trailer: Oliver Legacy Elite II
Mississippi
This is built into every propane tank already.
Steve and Tali - Dogs: Reacher and Lucy and our beloved Storm and Maggie (waiting at the Rainbow Bridge)
2017 Silverado High Country 2500HD Diesel 4x4
Steve Outlaw is offline   Reply With Quote
battery, casita, fridge
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Mike_L
Dead Battery After Towing Erik in Wisco Electrical | Charging, Systems, Solar and Generators 12 11-15-2013 09:44 PM
Solar Trickle Charger & Dead Battery V'sGlassSleeper Problem Solving | Owners Helping Owners 11 03-19-2010 07:29 PM
Help dead battery & still no lights plugged in- Mark J Problem Solving | Owners Helping Owners 8 12-09-2009 05:15 AM
