Delamination on 1986 Bigfoot - Fiberglass RV
Old 05-23-2009, 05:35 PM   #1
Tim D.'s Avatar
Trailer: 1986 17 ft Bigfoot
Ann and I have a 1986 17' Bigfoot rear bath. We've owned it for about a year now. Of that year we fulltimed 5 months, though 3 of those months were in one place with full hookups.
We love the lifestyle. We are taking the summer off to travel while fuel prices are down, intending to visit the Maritime Provinces and work our way west to British Columbia.
That is to say, we were. A couple of issues with our trailer, which we call Patience for good reason, are holding us up just now. I'd love a bit of advice. Pardon me for being long-winded but I'd like you all to know what I know from the get go.
Issue #1
All four sliding windows leak, not from the seal between window frame and fiberglass but through gaps between fixed and sliding panes, created by the shrinking of the wiper. The tracks fill with water that eventually spills into the cabin. Though I have cleaned the weeps with a 12" pipe cleaner, they do not drain quickly enough to prevent overflowing of the tracks. Additionally, all of the soft parts of the window assemblies have become, to one degree or another, rigid with time. Some of them are downright brittle. There is no visible water damage from this leaking.
This is a problem I know can be fixed, but not by me. I'm not particularly handy. The manufacturer, Sun-View Industries in British Columbia, still exists and for a reasonable fee is willing to completely rework the windows so they are like new.
Issue #2
The real problem is with the curbside side wall of the trailer. See photos at
Delamination
This issue just surfaced a few days ago as we began our big adventure. I noticed a ¼" gap had developed between the galley assembly [fridge/sink/furnace/range] and the interior wall of the trailer. This led me to the exterior, where I noticed that the side wall below the galley window was squishy—it had some flex to it unlike anywhere else around the belly band. The fiberglass is firm, it just moves in and out with pressure from the heel of my palm.
I opened the curbside refrigerator access panel located just below the side-wall mounted refrigerator vent [no refrigerator vent on the roof]. Sticking my head inside and looking up to the top of the refrigerator compartment I could see some water stains. Whether the source of the water is the refrigerator vent or the leaky window I am not sure.
Inside the refrigerator compartment all of the wood seems sound with the exception of the sheet of interior paneling, which is coming apart. Still, as a unit the fiberglass/interior paneling appears to have pulled away from the galley assembly.
From inside the cabin I stuck my head in a cabinet door of the galley assembly. All of the wood and interior paneling I could see, and I looked everywhere with a headlamp and a mirror, seems sound and I can see no water damage.
q Is this separation of the side wall from the galley assembly considered delamination?
q Though I can find no punky wood, some may exist unseen. Am I likely to incur BIG $ for repair to replace any punky wood and reattach the sidewall to the galley unit? We love our little trailer but at some point we would be better off looking for another one.
q Should I care? Is this just cosmetic and I can fill the gap with caulk and toodle down the road?
Thanks loads for your thoughts.
1991 Bigfoot 17 Rear Bath
2006 Dodge Sprinter
Tim D. is offline   Reply With Quote
Old 05-23-2009, 05:55 PM   #2
Ed Harris's Avatar
If I understand your description of the trailer and the problem then it sounds like the interior cabinet has simply drifted from the sidewall a little bit?
I can not get your picture link to work.
On my Fiberstream there seems to be no actual connection between the inside fixtures and the walls of the trailer except where they attach to the floor.
This has caused the exact thing I think you are talking about to happen for me.
Because there is no part of the galley touching the inside of the outer wall it will flex when pressed on from the outside.
This also causes it to look "wavy" or crooked along the sidewall without the interior fixtures to keep it all in line.
Some trailers have all Fiberglass interiors and they are glassed to the walls(Trillium) others have fiberglass fixtures riveted and screwed to the walls(Scamp.Casita) which should prevent this.
From what I have seen the Bigfoot is like the Fiberstream and the fixtures are stickbuilt and not attached to the walls.
I also don't think solid fiberglass can "Delaminate" as you put it because it is not laminated in the first place it is molded.
I have certainly seen trailers that had laminated walls but I don't think yours is one of them.
Again I can not see your pictures so I am not sure but I suspect you are talking about a normal wear occurance?
Ed
Old 05-24-2009, 06:51 AM   #3
Tim D.'s Avatar
Ed,
Thanks for the input. So sorry for the problem with the photo link. Try this: Delamination
Indeed the galley is stick built and a separate unit from the side wall. A vinyl gasket runs the interface between the two at the countertop. It could be that the galley has moved, but it appears that maybe the side wall has slumped?
2006 Dodge Sprinter
Old 05-24-2009, 09:12 AM   #4
Robin G's Avatar
Trailer: 2007 Casita
I don't think it's you that is not getting it. I tried posting the link and it turned my at into [at] hmmmm, I don't know! But I know if you copy his link then paste it into your browser and then Change the[at] to at it works. His pictures come up.
Tim, I am going to leave the answers to the experts, But I suggest that you chaulk it for now, enjoy your trip. As long as it is not a safety issue! Then when you have the time restore it, you should be able to find the right solution to make the repairs and have a great trailer. Your question about is it going to cost big bucks? Naaa, not as much as a new trailer and if you guys love this one it's worth the fix. There are many here who have done full restorations and I am sure they will have answers to guide you thru the issues. Again, quick fix for now and enjoy you trip. Robin
Old 05-24-2009, 09:18 AM   #5
Robin G's Avatar
I think if I remember right we can't link to that type of site. I may be wrong, but I remember reading it somewhere so heres you pics Tim.
Old 05-24-2009, 09:31 AM   #6
Ed Harris's Avatar
Tim
As I said that is exactly what has happened to my Fiberstream because the inside and outside are not really attached along the wall.
I think you are probably correct that the wall has slumped as without real support the weight of the roof and time conspire to help this occur.
I have spoken at length about this with Fred and other members of the groups and there seems to be a consensus about this.
That said I do not think it is anything to worry about at all.
I have devised all sorts of plans to correct it and try to prevent it from coming back but all seem to involve attaching through the hull to the inside somehow.
To me this may be more problem causing than solving so I am just letting it go for now.
On the Fiberstream it is the most pronounced at the entry doorway where the doorway is not really a true rectangle anymore and the door fits funny because of it.
The roof bears down there with the least resistance as the opening is well....open.
I think the really fix the problem the roof would need to be jacked up and into place somehow and then cracking might occur.
The trim on the inside was just to fill any gap and limit scraping of the fixtures against the hull. My gaps have also grown large like yours and the trim is attached from the inaccessable side of the counter tops so I can not really fix it easily.
There are several ways to seal the gap but just letting it be is also a solution.
Nice trailer by the way and congratulations it will be a lot of fun I am sure.
Ed
Most Fiberstreams seem to have this same issue.
Old 05-24-2009, 09:35 AM   #7
Robin G's Avatar
Heres the rest.....................
Old 05-24-2009, 03:01 PM   #8
Tim D.'s Avatar
Thanks, Ed and Robin. Likely what we'll do is just let it be for now. We were planning to put a couple solar panels on the roof, but if weight up there will aggravate the problem we'll wait on that.
Sorry about the mess with the pictures. I was just trying to save some space by posting the photos elsewhere.
2006 Dodge Sprinter
Old 05-24-2009, 07:26 PM   #9
Frederick L. Simson's Avatar
Thumbs down
If the link does not work, try replacing [at] with the "at symbol" So sorry.
[b]As a Moderator, I will explain here that the Moderating Team has contributed to your frustration a little bit in order to keep the [b]entirety of the membership here safe from computer hackers.
Unfortunately, this safety means we have had to program this website to not recognize [b]and surgically remove all vestiges of the character we must refer to now as the "at symbol". It was the best solution we could find to fixing a thorny and frustrating problem.
Automated computer "bots" were harvesting anything containing that forbidden character, and sending out viral spam at an exponential rate faster than mere mortals could subdue it.
Please, post photos directly here, we have plenty of space for them here. Actually, we would prefer it if they were here, and not on some other site.
We now return you to your regular program...
Old 05-25-2009, 06:41 AM   #10
Tim D.'s Avatar
Let's try this again. Thanks to Frederick for the heads up on posting images. I have found a program that can compress the images to a total of less than 400k, so here they are all in one place. Once again, my apology for the difficulty everyone has had in linking to the photos.
Inside_frige_compartment_looking_up2.jpg   Inside_frige_compartment_looking_up.jpg
2006 Dodge Sprinter
Old 06-17-2009, 07:59 PM   #11
Lizbeth's Avatar
Tim, just so you don't feel all alone.....our new to us 5th wheel started having the same problem this weekend on our trip. I know the seam between the wall and counter was tight when I scrubbed it a couple weeks ago. It's doing it on both sides, at the back end of the kitchen counter and at the little counter next to the fridge.
We are trying to figure the best way to fix it. At this point we are thinking of bolting through the belly band into the cabinets with some reinforcing added in some areas. This is in addition to the re curving of the flattening roof in the rear. I think we will make lemonade with our lemon!
Old 06-17-2009, 08:17 PM   #12
Attention, attention. If the site you're trying to link has the {at} sign, you can get around it by using a Tiny URL: http://tinyurl.com/create.php
I just did that for Tim's pictures on Flicker:
http://tinyurl.com/q4fagt
Old 06-18-2009, 05:21 AM   #13
Tim D.'s Avatar
Thanks for the solidarity, Lizbeth. A local RV repair shop advised us that repairs would not be cost effective, and that the trailer may survive years with the problem. We are still looking for a solution but not worrying so much.
You mentioned your roof flattening. Just so you don't feel alone, the front portion of our roof sags on either side of the fore/aft centerline. Not having seen another Bigfoot for comparison, we're not sure if this is the way they were made or if we have another problem. I've been up there and the roof seems strong.
2006 Dodge Sprinter
Old 06-18-2009, 10:08 AM   #14
Issue #2 .........This issue just surfaced a few days ago as we began our big adventure. I noticed a ¼" gap had developed between the galley assembly [fridge/sink/furnace/range] and the interior wall of the trailer. This led me to the exterior, where I noticed that the side wall below the galley window was squishy—it had some flex to it unlike anywhere else around the belly band. The fiberglass is firm, it just moves in and out with pressure from the heel of my palm.........
If your delamination / separation would happen on the flat piece of fiberglass I would use the process called vacuum lamination. The area which needs to be laminated is sealed with a bag; catalyzed resin is pumped into the joint while vacuum is being pulled out. In this process air is evacuated from the joint and atmospheric pressure is pressurizing components together. Well, you don’t have a flat and accessible piece of fiberglass but if there is a way to feed epoxy resin directly into separated space and provide mechanical force to joint components together during resin polymerization the end result could be almost as good. Use of multiple feeding tubes into this separation area and low viscosity epoxy resin Epoxy_from_West_Marine would assure full resin fill. The mechanical force could be applied by placing braces inside the trailer and forcing the fiberglass into the original shape from outside. This could be messy but I am certain rather permanent.
Just food for thought,
George.
GeorgeR is offline   Reply With Quote
Old 06-18-2009, 11:06 AM   #15
Lizbeth's Avatar
That is the same as ours except it's in the rear where there is no structure to support the roof.
Old 06-18-2009, 11:11 AM   #16
Lizbeth's Avatar
George our side wall don't seem to have come apart from the insulation and paneling. It's more of a bulge/sag in the side wall.
I think it's very interesting that BF didn't attach the outside of the trailer to any of the inside cabinetry. That seems like such a simple way to make the whole structure more rigid.
Old 06-19-2009, 04:18 AM   #17
Tim D.'s Avatar
Thanks, George. Possibly the trailer could be parked next to a wall as something to push against using a telescoping rod. Getting the epoxy to where it is needed might be tricky. Removing a window might provide access without drilling through the fiberglass. After squeezing in epoxy, would there be enough time to reinsert the window to be sure the opening doesn't distort, then apply the braces before the epoxy cures? Just thinking out loud.
And Lizbeth, I agree with you it does not seem that BF attached the galley unit to the wall of the trailer. Is it possible that BF wanted to allow for a certain amount of flex in the shell as the trailer bounces down the road? Once again, just thinking out loud.
2006 Dodge Sprinter
Old 06-19-2009, 12:42 PM   #18
You have an interesting problem. I had 97 Bigfoot camper and now have 08 Bigfoot 21RB trailer and did some modifications on both. I believe that Bigfoot was using cabinets or internal walls as structural elements. While modifying one of the cabinets on my camper I noticed that it was attached to wood brackets which were permanently attached to fiberglass. In my trailer the sink cabinet is solidly attached to the wall and the floor but I am not certain if it is indeed a structural element.
Thinking about potential way of using epoxy I came with the following process:
  • Build an outside jig to keep fiberglass contour during lamination. You could take use 2 or 3 2”X6”X8’ and cut their 2” side into the shape which would conform to the desire fiberglass contour (2”X6” will be perpendicular to fiberglass plane). Use 2X4 or 2X6 to build jig’s structure. As you suggested use a wall and the jig to force fiberglass to the desire shape.
  • Provide epoxy resin feeding structure from inside of the trailer. You could use gravity feed via multiple 3/8” Tygon like tubing. Drill multiple holes into you cabinet and inside plywood with drill diameter slightly smaller than outer diameter of chosen Tygon tubing. Forcing tubing into these ports should seal these joints. Place funnels on other ends of tubing and hang them high.
  • Seal all potentially leaking openings with a temporary tape such as ducting tape.
  • Force inside cabinets into the externally braced fiberglass wall using 2X4 braces against other side of the trailer. I would leave windows in place.
  • Pure low viscosity mixed epoxy resin with catalyst into the funnels while wishing for the best results but most importantly that you will never have to take it apart.
Good luck, George.
Old 06-23-2009, 06:31 PM   #19
Tim D.'s Avatar
Thanks, George!
2006 Dodge Sprinter
Old 10-04-2009, 01:41 PM   #20
Tim D.'s Avatar
We visited several RV and fiberglass repair shops for opinions about our problem, which seemed to be getting a bit worse with time. The gap between the galley and the side wall was widening. All but one shop said that to effect a repair the wall must be rebuilt from the inside. To do this, the galley unit must be removed, including refer, furnace, and oven. Such a repair would run $2500-$3500. Yikes!
We found one shop that told us that they could repair from the outside for much less. Since the $2500-$3500 estimates had us looking for another trailer, we decided to give them a try.
They removed the belly band in the vicinity of the delamination. They inserted larger, longer screws to hold the side wall to the galley and loo. Going through the refrigerator vent, they ran plumber's tape from the belly band to the galley unit. On the inside they placed a length of angle iron at the side wall/loo junction, where wood lies beneath the decor paneling.
Almost two weeks have passed and so far so good.
2006 Dodge Sprinter
bigfoot
Bigfoot roof delamination Daryl R Care and Feeding of Molded Fiberglass Trailers 11 07-14-2010 09:25 AM
1986 17ft Bigfoot Gina D. Referrals: Molded Fiberglass Trailers 0 06-13-2010 03:27 PM
1986 17' Bigfoot For Sale Tom Reynolds Classified Archives 6 05-07-2010 08:30 PM
1986 Bigfoot B19 Spiritwing ken&liz Classified Archives 3 02-16-2010 09:35 PM
20' 1986 Bigfoot 5th wheel Dana T Classified Archives 1 04-27-2009 10:25 PM
