Difference between automatic demand and switched pumps - Fiberglass RV
Old 04-11-2011, 07:10 PM   #1
GordM's Avatar
Trailer: Boler 13 ft 1972
Hi everyone! It's been a long cold winter and I'm back on the "need a pump" for my Boler. So I have been looking at pumps, and what is the pros and cons of automatic demand pumps, versus inline switched pumps? I've been looking for a low amperage pump, and most of the small stuff that is sold up here in Canada uses a switch. Any opinions either way? Thanks everyone!
GordM is offline   Reply With Quote
Old 04-11-2011, 07:16 PM   #2
honda03842's Avatar
Name: Norm and Ginny
Someone correct me if I'm wrong, but I think all RV pumps are demand pumps. They only pump water when you turn a open a water valve, at a sink or at the toilet. The switch is simply a convenience device to allow you to shut it off so it doesn't come on at all.
As to amperage, I never worry about it too much because even when you're using th pump it doesn't come on very often.
Norm
Old 04-11-2011, 09:17 PM   #3
Trailer: 1971 Amerigo
The pump in my Boler is controlled by a switch and if on runs constantly. It's a crank arm type pump with a rubber bellows - and it's loud enough to wake the dead.
I'm looking for a good demand pump as well...ideally one that's quiet :~)
Peter_Crowl is offline   Reply With Quote
Old 04-12-2011, 01:01 AM   #4
Trailer: Fiber Stream
I am planning on installing a manual foot pump in addition to my demand pump. this is what I have on my boat and I think it makes a lot of sense. First, it use no power, just a little foot power. Also you only pump what you need - no wasted water while turning on or off the faucet. You also have your hands free while pumping the water.
I find it much better for washing hands and brushing teeth. I will still have the demand pump for getting hot water and washing dishes. The pump I will use is a marine pump called "Baby Whale Gusher foot pump".
Steve
slbran is offline   Reply With Quote
Old 04-12-2011, 04:52 AM   #5
GordM's Avatar
So for a switch pump, you have to turn on the switch, which turns on the pump and then you can open the taps? Hmm, I have to then wire up the switch and the stuff I got to buy for that will be about equal to the difference I'd be saving.
Another question - do any of you use or have an accumulator as well? Or do you run from the pump to the taps etc?
Coleman Hot Water On Demand mcbrew General Chat 7 11-03-2010 11:39 AM
On Demand Water Heaters melissab General Chat 10 09-22-2010 11:53 PM
Automatic vs. Manual Transmission Mailie Towing, Hitching, Axles and Running Gear 8 06-19-2010 05:30 PM
Automatic Transmission Stuf Pete Dumbleton General Chat 0 05-01-2008 09:11 PM
Automatic Transmission Fluid Temperatures Pete Dumbleton General Chat 1 03-04-2008 04:53 PM
