Dim tail lights - Page 2 - Fiberglass RV
Old 08-03-2012, 09:20 PM   #15
CliveAlive's Avatar
Trailer: Boler American #3104
OK I'm just going to come right out and say it ...
I think you should just take off all the rear lights that the PO added, (fill the holes) and replace those 4" round ones on the light housing with 7" LEDs.
Clean it right up!
Old 08-03-2012, 10:15 PM   #16
Roy in TO's Avatar
Only if they can't find the same 4" fixture in LED. I think that is unique to the trailer.
Then again they could change the bulb with a LED replacement
Old 08-04-2012, 08:14 AM   #17
Originally Posted by nlife View Post
It looks as though the PO took the light housing out and reversed them. The French style lights appear to be inside out if you will.
Probably because they didn't want to cut into the body... those buckets stick inside quite a bit and who knows what may behind that area, if mounted like original Bolers. I've been given a set of broken french buckets and I'm racking my brain on how to mount on my Scamp. These inside-out may be the ticket... with round LED tail lights of course.
Be seen, be safe!
Old 08-04-2012, 03:35 PM   #18
Just saw these at princess auto. 4" round LEDs
nlife is offline   Reply With Quote
Old 08-04-2012, 03:44 PM   #19
Trailer: 1973 Love Bug '13
Attachment 49615
thanks,
Cat futrell is offline   Reply With Quote
Old 08-04-2012, 05:07 PM   #20
Roy in TO's Avatar
And they are on sale!
Old 08-04-2012, 05:24 PM   #21
Thanks Roy! Your awesome!
Old 08-04-2012, 05:42 PM   #22
Roy in TO's Avatar
Cathy, it was nlife that found them. You should be thanking him.
I did not realize they had Princess Auto in California, or is Neil visiting up here?
Old 08-04-2012, 05:44 PM   #23
My apologies nlife. Roy is not Awesome, YOU are!
Old 08-04-2012, 06:38 PM   #24
Roy in TO's Avatar
I'm starting to feel a little inferior now. Can I be OK for noticing they were on sale?
Old 08-04-2012, 07:01 PM   #25
Sure Roy, You are OK. Didn't mean to make you feel bad.
Old 08-04-2012, 07:14 PM   #26
While we are still on the subject of lights, the tail lights are very low (to the ground). Anyone added a light on the upper corner of the cabin?
Old 08-04-2012, 07:49 PM   #27
Those are typically called Third Brake Lights: third Brake Light - Google Search
unless you're asking for dual tail lights...
Old 08-04-2012, 08:00 PM   #28
I am just thinking that the visibility from the back is not great. Even with bright tail lights they are low to the ground. The visibility from the side is nil. The tail lights aren't visible from the side. Maybe I'm talking about running lights. Is there something small that would match the style for the trailer and could I wire it to the tail lights.
lights
Can you see me now?---New tail lights Kevin K Modifications, Alterations and Updates 22 09-11-2011 11:10 PM
LED lights in Original light sockets - tail lights Cam A Modifications, Alterations and Updates 75 02-15-2009 10:54 PM
Very Dim Tail Lights Will Wi Problem Solving | Owners Helping Owners 2 07-16-2008 09:23 AM
New Tail Lights - Help! Chris73 Problem Solving | Owners Helping Owners 13 07-12-2006 10:43 AM
Tail lights Legacy Posts Problem Solving | Owners Helping Owners 32 07-27-2003 09:29 AM
