Dinette table trim - Fiberglass RV
Old 06-30-2015, 06:10 PM   #1
Judy Jensen's Avatar
Trailer: 2000 19 ft Scamp 19 ft 5th Wheel
Dinette table trim
Hi~
The trim around my dinette table has gotten brittle and cracked and was wondering if anyone else has/had the same problem. I didn't see the same trim on the Scamp parts website and was curious if someone has a solution/idea or found a vendor that carries this type of trim.
Judy Jensen is offline   Reply With Quote
Old 06-30-2015, 06:30 PM   #2
floyd's Avatar
Originally Posted by Judy Jensen View Post
Hi~
for just a few dollars you could make a new table top of Oak veneer plywood and trim it with iron on veneer.
Old 06-30-2015, 08:23 PM   #3
Trailer: 2013Escape 21
Iowa
Table moulding
You did not describe what the moulding consists of and I am not familiar with the Scamp tables. If the table top is 3/4 inch thick plywood or something near that you could remove the old moulding, sand the edge smooth and install a vinyl T moulding by cutting a slot in the edge of the top with a slot cutter bit driven by a router. That's how I made a new table top for my Escape. You can buy the T moulding on the internet, there's several colors. They also use this product on the edges of stand up video games. You have to trim the T leg off for a distance of about an inch and a half on the corners and short radii. It's a barbed leg so it's just a friction fit with no adhesive needed. The whole job would not take an hour from start to finish if you can find someone with a router and a slot cutting bit.
Dave
Iowa Dave is offline   Reply With Quote
Old 07-01-2015, 06:09 PM   #4
Thank you both very much for your replies. That is really a lovely table Floyd! I didn't give very much info, but the t moulding that you mentioned Dave sounds like what I need. The table does have a notch so will see what I can find on the internet-I wasn't sure of the correct name of the trim.
Thanks again
Old 07-01-2015, 08:37 PM   #5
Iowa
Dinette table trim
If your table top is slightly less than 3/4 inch thick, after you thump the moulding into the slot and it's tight to your liking, you might notice that the top edge of the moulding is a little above the table edge "proud". You can trim it to fit with a good utility knife laid carefully at a filet type angle. The color goes all the way through so don't worry about a contrasting edge. Lots of 3/4 plywood is 23/32nds of an inch and the laminate thickness does not always make up the difference. And the slot may not be cut exactly dead center. Good luck.
Dave
Aluminum trim for table Kevin M Problem Solving | Owners Helping Owners 25 08-08-2014 08:52 PM
Burro Trim Lok and door trim/seal nomadicitch Problem Solving | Owners Helping Owners 2 01-19-2014 08:27 PM
Trim for table edge Steve in TX Modifications, Alterations and Updates 3 12-22-2010 09:13 AM
Aluminum Table Trim Legacy Posts Problem Solving | Owners Helping Owners 9 07-16-2003 09:02 AM
