Do I have DOOR SAG?!?!? Plz help sobbing woman. - Page 2 - Fiberglass RV
Old 08-23-2010, 08:41 PM   #15
Trailer: 1976 Boler 13 ft
Cyndi Im having are hard to time seeing you taking your trailer to have the hinges done considering all the work I know you have done on your trailer. I am assuming this was when you first got the trailer and before you got your hands dirty!!!!! :-)
BTY I got brave this weekend and finally cut a big hole in the closet, hung a new door and put in a pantry! Love it. What was I so scared of!
Cant wait to see it at ft langley in september. i am considering extending my pantry a bit with a new door seeing as mine is warped. that reminds me, i meant to post about that.
cyndi H is offline   Reply With Quote
Old 08-31-2010, 05:47 PM   #16
Bruce Thomas's Avatar
Trailer: Hunter compact jr
Indiana
Hinges look bad or out of alignment to me from your picture.....shouldnt be too hard an adjustment . Bruce
Bruce Thomas is offline   Reply With Quote
Old 08-31-2010, 06:53 PM   #17
Vickie B.'s Avatar
Trailer: 1988 Perris Pacer ('Bean') / 2015 Ford F-150, 2017 Winnebago UltraLite 27BHSS
Nebraska
Thanks Bruce----had to take a time out as my daughter is visiting from Germany for the next 2 weeks---then I'll get back to the camper! Hope it is something simple!
Vickie B. is offline   Reply With Quote
Old 09-05-2010, 07:54 PM   #18
Vickie B.'s Avatar
Nebraska
Here's some more pics of the door/hinges---so---is it a simple hinge problem???
Old 09-05-2010, 10:33 PM   #19
Raya's Avatar
Well it does look like the brass balls that sit inside the hinges are worn down (because I can't see them and they usually show through). So, if they look that way on in-person inspection, I would start by ordering two of those from Scamp and then re-evaluating. You could also have one or more of the other issues going on (I can't tell from what you are posting), but you might as well start with the hinge balls (at least, I would).
You have to order two sets from Scamp, because a "set" only does one hinge. I think the scamp bolt and nut are non-stainless, so I would replace those with stainless (in other words, I would just use the balls from the kit and then go stainless for the rest).
Raya
Old 09-06-2010, 07:46 AM   #20
Here is a picture of a hinge from Scamp showing where the ball belongs.
Bill K
Pair Of Outside Door Hinges
Old 09-06-2010, 12:03 PM   #21
Raya's Avatar
Good idea to add a photo, Bill
Not only does it look like Vickie's are worn down or missing, but you can see where it has started to cut into the upper part of the hinge body in her last photo. Luckily that should not come into play once the new balls are in there.
Vickie, I would definitely get a set of these and install them before I did anything else. Maybe that is all (or most) of your problem. Certainly it's hard to judge the rest of the problems (if they even exist) without the balls in the hinges.
(I was thinking that *maybe* the Perris Pacer hinges did not use the balls, but I highly doubt that, especially looking at that last photo.)
Raya
Old 09-06-2010, 02:36 PM   #22
Indiana
whats surprising is that you could open and close one of those doors enough to wear out that part. In the future.....any lube will help.
Bruce
Old 09-06-2010, 06:56 PM   #23
I'm wondering if at one time the door might have had a bit of bind in it and a previous owner took the ball out and the spring off the shaft of the bolt... that's missing too.
Here's the parts needed: http://shop.scamptrailers.com/p-334-...-nut-bolt.aspx to do a repair, just remember even if it says SET... it's only for one hinge... you need to order two sets!
Old 09-06-2010, 08:30 PM   #24
Vickie B.'s Avatar
Nebraska
Thanks friends! I'll be ordering those TWO sets of hinges!!!!
Old 09-06-2010, 08:36 PM   #25
Vickie, be aware the hinges for the Scamp are three bolt on the body and two on the door. Your PP are two bolt in both places. I don't know if two of the holes are going to line up in the same place as two holes for the Scamp hinges. If there's no cracks in your PP hinges you may be able to just buy the replacement parts from Scamp, not the entire hinge setup. Only you can tell if you really need to replace the entire hinge.
Old 09-06-2010, 08:48 PM   #26
Vickie B.'s Avatar
Nebraska
Yikes! Thanks Donna for the heads up (is nothing simple?!?!?!?)
Old 09-06-2010, 09:35 PM   #27
Raya's Avatar
Well just getting the ball kits *is* simpler, presuming they fit. It's what I'd be trying first.
Boler door sag fix help needed Michael Collins Problem Solving | Owners Helping Owners 46 06-11-2016 03:32 PM
Improving door fit due to body sag Roy in TO Modifications, Alterations and Updates 41 06-02-2013 05:25 PM
Door Sag/Shell Bowing Out cyndi H Problem Solving | Owners Helping Owners 23 04-21-2010 11:58 AM
Door sag? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 7 08-19-2003 11:11 AM
Door sag? Legacy Posts Problem Solving | Owners Helping Owners 2 07-13-2003 11:55 AM
