Do I need to replace my propane tank regulator? - Fiberglass RV
Old 09-02-2011, 12:35 PM   #1
Kevin K's Avatar
Trailer: 1983 13 ft Scamp
I think this is a original 1983 regulator. My problem is the white thing on the top rotted away.
What is it for?
Did a soap test NO gas leaks.
Should I replace it?
Stills works.
Old 09-02-2011, 01:02 PM   #2
floyd's Avatar
What is it for?
Stills works.
Attachment 39593
If it fails it will likely fail internally and cause aggravation while you are trying to recreate.Eventhough they are reliable ,a new one is cheap insurance, while you are at it, check the hose for surface cracks.
Old 09-02-2011, 01:39 PM   #3
What is it for?
Stills works.
Attachment 39593
The fact that you are thinking about is a pretty good indicator that the answer is "yes - you should replace the regulator plus any & all hoses"
If in doubt - on something safety related - don't take chances!
Old 09-04-2011, 12:42 PM   #4
Kevin K's Avatar
Single-Stage Regulator
or
Two stage Regulator
Which one should I buy?
Old 09-04-2011, 02:49 PM   #5
Perry J's Avatar
If everything works well and there are no leaks I would roll the regulator on it's side so no water collects in the recess and forget it.
John
Old 09-06-2011, 04:06 PM   #6
Rick G's Avatar
Smile
What is it for?
Stills works.
Attachment 39593
Hi,
The cover is important for two reasons. One, it prevents a very small leaking of gas through the regulator adjustment mechanism. I have been able to hear a slight whistling noise on occasion when I have had the cover off. Two, the pressure adjustment is directly inside the cover. Without the cover, your propane pressure could get adjusted without you realizing it.
New two stage regulators are only about 30 bucks at any RV dealer, so I would replace it. The old one stage regulators are no longer considered to be safe, although they worked fine for decades. Plus, if the cover has rotted away, I would wonder why. It seems very odd.
Rick G.
Old 09-06-2011, 10:07 PM   #7
Kevin K's Avatar
I think because it's 28 years old.
Old 09-07-2011, 08:51 AM   #8
Greg H's Avatar
Trailer: 72 Boler American
Indiana
They sell singles everyday at the hardware stores, I use singles on everything.
Old 09-08-2011, 04:23 PM   #9
Trailer: Trillium 4500 1977
Quebec
LP regulator change
Propane fridge and heater require accurate and regular supply of 11 inch of gas pressure, as indicated in the user's manual. Jetting is calculated for best results using such pressure. The two stage regulators are more accurate than the one stage regulator wich are OK for BBQ or stove top, but not for main RV supply.
Old regulator is likely to become innacurate and reduce fridge and heater efficiency. If you replace it, you should get the special sealing paste or yellow teflon tape on the thread. You may also want to check if there is not a water buildup on the lowest part of your pipes under the RV floor. This would compromise free flow of gas.
Gas is just too important and dangerous to tolerate questionnable equipment.
Martin J. Qc Canada
lamimartin is offline   Reply With Quote
Old 09-08-2011, 04:28 PM   #10
Kevin K's Avatar
lamimartin GREAT information.
propane
Propane Regulator Greg G. Care and Feeding of Molded Fiberglass Trailers 7 07-14-2010 07:46 AM
Question about propane regulator Bobbie Mayer Problem Solving | Owners Helping Owners 13 02-14-2010 03:29 PM
Propane regulator Dana T Problem Solving | Owners Helping Owners 1 09-20-2009 02:34 PM
Propane regulator Kevin K Problem Solving | Owners Helping Owners 9 04-24-2008 05:08 PM
Propane Regulator Replacement Don Nicodemo Problem Solving | Owners Helping Owners 2 08-06-2006 05:34 PM
