Does Anyone Know How to Fix A Surge Braking System? - Fiberglass RV
Old 04-17-2007, 12:36 PM   #1
Trailer: 28' Bigfoot Silver Cloud
Woodstock, IL
When we picked up our 16' UHaul, we were told the surge braking system needed repair (the PO said the cylinder needed repair). What do I look for? Does anyone have any experience with this type of braking system?
Kevin
Old 04-17-2007, 02:50 PM   #2
pjanits's Avatar
Trailer: 17 ft 1986 Burro
I suggest you make friends ( pizza /beer) with the local U-haul guy and see what he says. U-haul usually has special made stuff. Maybe you could get parts thru him.
Old 04-17-2007, 03:42 PM   #3
Woodstock, IL
My experience with UHaul dealerships is that they are often run by some local guys who find it difficult to get my equipment registration right and are about 19 years old. There is a dealership in Forest Park near us, so I'll try there but I'm not expecting much help!
Old 04-17-2007, 03:44 PM   #4
Gina D.'s Avatar
West Coast USA
Try a boat trailer place.
Surge brakes are very common on them.
Old 04-17-2007, 06:00 PM   #5
Brian B-P's Avatar
No direct experience, but a hydraulic surge brake system is just like the brakes in a car, but with no power assist, and with a linkage in the coupler instead of a brake pedal. The master cylinder in the coupler works exactly like one in a car, and would be rebuilt the same way. For many cars, it is cheaper to replace the master cylinder than to rebuild it; I have only replaced them.
In addition to boat trailers, just about any rental trailer heavy enough to legally require brakes is likely to have the same type of surge brake system, so many trailer fabrication, rental, and repair businesses will be quite familiar with them.
If you can pull the master cylinder out and take it with you, I think a good auto parts person would be valuable - they may be able to match it, despite its trailer origins.
Old 04-18-2007, 05:48 AM   #6
Craig Nold's Avatar
Trailer: 1999 Casita 16 ft Spirit Deluxe
Kevin,
As with electric trailer brakes, most hydraulic trailer brakes are/were made by Dexter. You will find a wide range of parts at the Dexter online store but you may need to call Dexter for identification of the parts to fit you trailer. (574) 295-7888 I would start with the master cylinder. Fill it with brake fluid and check for leaks. If the fluid runs out, call the boat trailer place. If the fluid doesn’t run out, call the boat trailer place and have them check it out anyway.
http://dexteraxle.com/brake_cylinders___rebuild_kits
Craig Nold is offline   Reply With Quote
Old 04-18-2007, 10:09 AM   #7
Woodstock, IL
Kevin,
Thanks! This will get me started on the process. Your comments are much appreciated!
Kevin
Braking controllers Matt in SV Towing, Hitching, Axles and Running Gear 2 06-04-2010 04:29 PM
TV Braking Issue Tamid Problem Solving | Owners Helping Owners 9 04-14-2009 05:11 PM
Braking, Transmission for towing Paul Kaplan Towing, Hitching, Axles and Running Gear 5 06-30-2008 06:14 PM
Why not surge brake? EricMeyer Care and Feeding of Molded Fiberglass Trailers 12 04-17-2008 07:11 PM
Uneven trailer braking John & Sandy M Care and Feeding of Molded Fiberglass Trailers 15 02-03-2007 01:18 PM
