Does this sound right? - Fiberglass RV
Old 09-23-2016, 05:44 AM   #1
Trailer: 2012 Casita Spirit
St. Petersburg, FL
I took my 2012 Casita in for the wheel bearings to be greased. The shop told me that the shoes and pads on the brakes were bad and that I needed a whole brake job that had to include a brake motor because our trailer's brake system comes as a package. They want to charge me $600 for the whole job. Does this sound right? Thanks in advance for any advice.
Sherritini is offline   Reply With Quote
Old 09-23-2016, 06:25 AM   #2
Alf S.'s Avatar
Trailer: 2014 Escape 5.0TA / 2010 Nissan Frontier
Hi: Sherritini... Get a second opinion!!! Now.
Old 09-23-2016, 07:41 AM   #3
Paul O.'s Avatar
Trailer: '04 Scamp 19D, Tacoma 4.0L 4door, SB
ex VT, now CO
Yeah, I second that!
Old 09-23-2016, 08:30 AM   #4
Raz
Raz's Avatar
Vermont
I don't know what a brake motor is? Your trailer has drum brakes. The brake shoes come mounted on a backing plate. One plate per side, mounts with 4 bolts and two wires need to be connected. The drums come in a kit that includes new bearings that require greasing. You can buy the parts online for around $200-225. Assuming a mechanics mark up say $300. Labor depends on the local rate but an experienced mechanic should be able to do the job in 2 hours or less. Perhaps others will jump in but I think $500 would be generous.
Old 09-23-2016, 08:55 AM   #5
Johnny M's Avatar
Deep South
Unless the drums are excessively worn you should be able to have them turned and replace the brake shoes. Turned means the drums are put on a lathe machine that puts a new finish on them where they contact with the shoes so to correct any distortion from heat induced warping caused by breaking, this ensures that they wear the new shoes evenly too and give you optimum braking control. The shoes should have a part number stamped on the metal, any reputable brake shop should be able to do this, whether or not the brake shoes are in stock depends on how common a part it is and upon the local auto parts supplier. I think replacing 2 shoes and turning 2 drums including labor should not go over $200-$250 IMHO.
Old 09-23-2016, 08:55 AM   #6
Perhaps the whole diagnosis is bad?
The trailer is 4 years old.
It is likely that the bearings really don't need greasing at this point and the seals ans shoes are good as well.
When you deal with a crook, when do you stop believing him?
I have no idea as to how many miles on the trailer, but if the bearings had not been greased before it is unlikely that they were over greased and the seal blown out geting grease on the drum ans shoes.
You need another HONEST mechanic and you need to look at the parts.
Brake Motor??? Really?
Did he say the brake light fluid needed to be replaced as well?
Old 09-23-2016, 08:59 AM   #7
Johnny M's Avatar
Deep South
Also to back this up JustBrakes is running a $99 special to turn rotor (similar to drums) and replace pad (similar to shoes) for the front or rear of most cars for $99, coupon is on their website
Old 09-23-2016, 09:04 AM   #8
Trailer: Bigfoot B-17 CB
"Shoes and pads are bad"??? Shoes, not likely, maybe, but not pads because they don't exist ! Brake motor does not exist either. Suggest you find a different shop.
Jack L is online now   Reply With Quote
Old 09-23-2016, 09:46 AM   #9
Civilguy's Avatar
Puget Sound, WA
As others have said there are no pads or motors. There is a magnet which "can" wear over time.
A quick look says about $84 per wheel for complete Dexter brand (your axle manufacturer) replacement parts including bearings, drums, brakes with backing plate, shoes and magnet. Those two kits would replace everything. A mechanic will have a somewhat higher price which is "OK" in that they have to make enough to stay in business.
https://trailerparts.com/dexter-elec...-3500-lbs.html
https://trailerparts.com/10-drum-5-o...-8-247-05.html
(The above parts are for a 3,500-pound axle as fitted on the 16' and 17' Casitas.)
However, the bigger question is whether you really need anything at all. I have a 2012 Casita that I don't really know the history of as we just bought it a year ago. I recently had a shop repack the bearings. The brakes and bearings and all parts there were in fine condition.
Ask questions and, if need be, check with another shop. The blessing here will be eventually finding someone that you can trust.
- "Character is what you do when nobody’s looking." -
Old 09-23-2016, 11:03 AM   #10
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
Just as a reference point, when I swapped out the axle on my Bigfoot, including new brakes, parts and labor came to $300. That's admittedly cheaper than a Casita would be because I have a simpler axle, but the brakes are the same.
Walt
WaltP is online now   Reply With Quote
Old 09-23-2016, 11:14 AM   #11
<cut>
However, the bigger question is whether you really need anything at all. .
I only paid for a complete Dexter brand brake assembly under $30 a side for my 92 trailer (first time originals had been replaced). Had the hubs spun and cleaned up for about $50.
Would be very odd that a new trailer such as the OP's actually even need a new complete brake assembly let alone hubs! If it does something is very very wrong
Have no idea what the heck the brake motor is that the OP's trailer supposable needs but it sounds interesting. Would love to hear the mechanic they are using explain it :lout
As others have suggested take the trailer elsewhere and get a second opinion.
Old 09-23-2016, 11:16 AM   #12
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Casita brakes
Shoes 13/64 .2031 NEW 5.1594 mm
Shot 1/16 or .0625 or 1.5875mm
#3500 lb axel
10x2 ¼ drum
Old 09-23-2016, 12:06 PM   #13
widgetwizard's Avatar
Walt
Hey Walt - how can the axle be any simpler than undoing 2 bolts per side?
Retired from Orbital Machine Works.
Where is Jim now? Here.
widgetwizard is offline   Reply With Quote
Old 09-23-2016, 12:34 PM   #14
OP's misspelling of "brake rotor" or spellcheck making a change probably. And the shop incorrectly calling the brake drum a "brake rotor"
mary and bob is online now   Reply With Quote
Central a/c Bang Sound & Stopped Working barryra General Chat 2 09-11-2010 07:17 PM
Sound System Needed... Please Nancy in Oregon Oregon Gatherings 4 07-12-2008 03:56 PM
Edifer Sound Doug Mager Problem Solving | Owners Helping Owners 6 04-26-2007 04:36 PM
Does this auction sound like a scam? Classified Archives 0 12-31-1969 07:00 PM
» Virginia Campgrounds
