doing repairs on the roof... - Fiberglass RV
Old 11-09-2008, 09:56 AM   #1
April Wilcox's Avatar
Trailer: 13 ft Scamp 1983
This may be a silly question, but we are about to take on some work that requires being on the roof of the Scamp. Kirk weighs around 140lbs, will it be safe to put that much weight on top in order to get the fan installed, etc...
April Wilcox is offline   Reply With Quote
Old 11-09-2008, 10:06 AM   #2
Alf S.'s Avatar
Trailer: 2014 Escape 5.0TA / 2010 Nissan Frontier
Hi:April... I installed the MaxxFan in the roof of our former Boler. Nice thing with that fan is you only install the mounting ring before hoisting the fan into it. No need to be on the roof!!! One person on each side/and or one in one out. 140lbs + the weight of the fan is TOO much!!!
Old 11-09-2008, 10:22 AM   #3
We already bought a fan, Shurflo gold and will have to cut the hole for it.
We also wanted to put a new exit hatch in the place of the old one that is cracking and mildew stained. Are we supposed to do the work from the inside? It seems to me that some of the work will have to take place above, and I am not sure how we are supposed to go about this. The old exit hatch is held in with rivits, and I am not sure how to remove them either. I know this has been discussed before, but I can not find the thread.
Old 11-09-2008, 10:58 AM   #4
Alf S.'s Avatar
Hi: again... A lot of leaning off the ladder worked for me. The pop rivets must be drilled out from the cap side. They aren't too hard so go slo & don't drill all the way through. Pull back the liner material so you have enough to finish up to the fan shroud and cut the fiberglass with a jig saw or Dremel saw. Good luck p.s. if you want send me a personal msg. with your email add. and I will send you a guest pass to view my install. photos. Regards Alf
Can I safely lay on the roof of my Bigfoot Trailer to make repairs ROIDON L Problem Solving | Owners Helping Owners 4 05-09-2009 11:40 AM
Toilet repairs Errol Holbrooke Plumbing | Systems and Fixtures 2 05-04-2009 08:52 PM
Fiberglass repairs Per Walthinsen Problem Solving | Owners Helping Owners 7 04-23-2008 07:27 PM
Foreign Car Repairs Pete Dumbleton General Chat 0 02-22-2008 01:34 PM
vehicle repairs Jeanne and Steve General Chat 6 08-23-2006 01:12 PM
