doing the math... squeezing inches - Fiberglass RV
Old 11-14-2007, 10:01 PM   #1
Michael M's Avatar
Trailer: Compact Jr
so we're strongly considering a newish 13' Scamp but we want to make sure it fits in the garage. can anyone tell me what the actual trailer height is (total height minus ground clearance)? we're considering rolling it on 10" rims like many others in this forum have done but it would help if we had some numbers...
thanks in advance!
Michael M is offline   Reply With Quote
Old 11-14-2007, 10:18 PM   #2
Steve L.'s Avatar
Unless you get something specific a quick search turned up this post where it was said that Scamp advertises 7'4'' on stock tires presumably.
Scamp Height
If someone could tell you or you know what the stock tire you could certainly swag the height drop. Say it was 13" a 10" would be about 1.5" plus some amount for the tire section heights which you could also swag (cross section times aspect ratio divided by 100 divided by 25.4).(P185/75R14 would have a section height of 185mm times 75 divided by 100 divided by 25.4 to get inches) Compare that to whatever 10" tire you're looking at.
Without adult supervision...
Also,
Old 11-15-2007, 06:37 AM   #3
Newish.... hummm subjective term. When it comes to a trailer with torsion suspension, I'd say it depends on the age and prior use of the trailer. They do have a tendency to squat over time and with many miles.
If the trailer must fit in the garage, your best bet is to ask the seller to measure it for you. We can give you all the numbers in the world... and it still might not work out for you.
Old 11-15-2007, 06:58 PM   #4
Greg A's Avatar
My 13 Scamp was about 86" and I had 94 clearance on my garage door. As Donna says, I've seen a variety of different measurements from folks up here, so do make sure you measure the actual trailer for the clearance. Remember, you can let some air out of the tires to gain more clearance when putting it away in the garage.
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 11-16-2007, 08:18 AM   #5
Alf S.'s Avatar
Hi: My Daddy always told me... "Measure twice...cut once". Remember that the new Scamps from the new Post Fire Factory are about 3" taller totally as the new 13' molds were taken from the 16' trailer!!! I would like to put our '77 Boler in the garage to work on the "Door Sag" but I don't want to risk the new MAXXFan
Old 11-16-2007, 08:41 AM   #6
Kevin K's Avatar
Trailer: 1983 13 ft Scamp
My mid 80's 13' Scamp is 83" to the top . BUT I changed the top vent so i could fit it into my garage.
New vent ----> http://www.fiberglassrv.com/board/index.ph...665&hl=vent
OK you math wizards--I dare ya! Vickie B. Problem Solving | Owners Helping Owners 15 09-26-2009 05:15 PM
Towing Stuf and Some Math Pete Dumbleton Towing, Hitching, Axles and Running Gear 4 03-14-2009 06:33 AM
Math and Stingers Sharon Herman Problem Solving | Owners Helping Owners 2 05-04-2007 05:04 PM
