Aha. I see that the converter is only rated for outputting 3.2 amps, so I assume that this
Fridge was installed after manufacture. The PDF parts manual only lists an icebox, but was this a CT feature, where the VT's might have had refrigerators?
Would installing a larger converter be dangerous? Quadrupling the amperage in the wiring harness is probably not a good thing.
Thanks Thomas!
