Dometic 3 way refrigerator freezer door - Fiberglass RV
Old 01-26-2019, 09:46 PM   #1
Trailer: 1985 Scamp 13
TX
Hi! I'm looking for a Dometic RM2118 freezer door. Mine is broken where the plastic fits inside to keep it on.
bojetty is offline   Reply With Quote
Old 02-02-2019, 07:28 AM   #2
Scamper Jim's Avatar
Betty,
Do you mean that the actual door is broken, or the plastic hinges on the ends that have springs to keep the door closed?
If you just need the hinges and springs, you can get them here:
https://www.google.com/search?q=dome...+housing&cad=h
The Utube vids for installing them are also good. They were very helpful when I replaced mine.
Cherokee RV has been bought by 5 Star RV in Brighton (Denver). They have a whole mess of used parts in the tent. Five Star RV - 303-659-1725
There are many others through out the US.
Jim
Scamper Jim is offline   Reply With Quote
Old 02-02-2019, 09:50 AM   #3
TX
Hi Jim, it's the plastic little "bump like" piece on the freezer door that fits into the little hole on the fridge. The tiny plastic bump has broken off so the door doesn't stay on anymore. I've thought of melting something plastic in it's place, but not sure that will last. Thank you for your message.
Old 02-02-2019, 10:51 AM   #4
Betty,
I am not sure what you mean by a "bump like" piece you are referring to. Is it along the top of the door, or on the two sides? Could you post a pic of it?
Jim
Old 02-02-2019, 01:53 PM   #5
TX
Sorry, Jim. I'm not good at explaining things. I'll take a picture of it tomorrow.
Old 02-03-2019, 01:58 PM   #6
TX
Ok Jim, hopefully I can get the photos on here for you. https://www.facebook.com/photo.php?f...W7SpwD9IEoexKX
Old 02-04-2019, 11:33 AM   #7
North Dakota
I have one for another model but they are probably all alike. I'll be home in a few days. Will send a pic.
Gene Masse is offline   Reply With Quote
Old 02-04-2019, 06:11 PM   #8
TX
Thank you, Gene!
Old 02-09-2019, 11:18 AM   #9
Trailer: BigFoot
bojetty
Any chance you can post the pics in this forum rather than going to Facebook? We are no longer on Facebook.
Rzrbrn is offline   Reply With Quote
Old 02-09-2019, 01:33 PM   #10
TX
Originally Posted by Rzrbrn View Post
bojetty
I'll try to do that. Thanks!
Old 02-17-2019, 11:06 AM   #11
Name: Bart and Kathy
This might fit. Will send info later today.
Bjkj is offline   Reply With Quote
Old 02-17-2019, 03:47 PM   #12
TX
Ok, thank you!
Old 02-17-2019, 03:56 PM   #13
North Dakota
Is this what you want?Click image for larger version
ID:	127938Click image for larger version
Old 02-17-2019, 04:16 PM   #14
Trailer: BigFoot
Thanks for posting the pics Gene.
Old 02-17-2019, 05:09 PM   #15
TX
Thanks Gene, but mine is different. It has no hinges. It has a small plastic piece that fits in small holes at the bottom and top. I wish this one would work. I appreciate you taking the time to show it. I still don't know how to post pictures on here. Sorry
Old 02-17-2019, 06:01 PM   #16
cpaharley2008's Avatar
Ask a moderator to post them for you....
Jim
Never in doubt, often wrong
Old 02-26-2019, 11:46 AM   #17
Joe MacDonald's Avatar
I rebuilt the bottom portions of mine with a product called Devcon steel.
it's a little like making a two part epoxy, then goes on like bondo, very hard to work with when cured, so make as neat a repair as possible, if you need a hole in it, use an insert if you can find something the same diameter mine had two holes at they bottom that had both broke away and the door wouldnt stay on I mixed a batch, slathered in on, then put the inserts in place, used a putty knife to scrape off excess, and let it cure, when it was solid, I used a file to clean up rough edges, not pretty, but it has worked for 3+ years
joe
Old 02-26-2019, 02:52 PM   #18
Trailer: BigFoot
Thanks Joe. Devcon steel: I gotta remember this.
Old 02-26-2019, 07:05 PM   #19
TX
joe
Thank you, Joe. I will try that. The bottom to mine is good....It's the top tiny piece that fits into the hole that is broken off. I'll let you know how it goes.
Dometic portable AC Freezer/Refrigerator dcs02d General Chat 11 07-18-2017 08:05 AM
Looking for Dometic freezer door hinge Greybeard Problem Solving | Owners Helping Owners 2 12-17-2011 07:02 PM
Freezer door for Dometic 2201 fridge Carol H Classified Archives 3 08-30-2011 11:27 AM
