Dometic cooling problem using propane - Fiberglass RV
Old 09-28-2014, 02:56 PM   #1
Trailer: Casita 17'
2001 17' Casita
Dometic RM2354 3 way refrigerator
Situation/Problem: frig works great on 110V AC, however, propane doesn't cool the frig section. (Never use the DC setting)
The propane setting does not get the frig section cold: thermostat set at Max and after a 20 hour test period, the frig section went from a starting temp of 77F to 44F. The freezer went from 78F to -3F. The freezer actual got down to 13F in 5 hours. Ambient temps were 70F to 80F. When the ambient temps are in the mid 90's, the frig can't get below 60F.
The 110V AC operation is fine. After the above test period, I set the 'fuel' to AC and the thermostat to 5. In two hours, the frig section went from 44F to 20F and freezer from -3 to -10F.
Gas pressure at the test port is 11.2" water. Gas orifice was cleaned and appears in tack. Burner was cleaned and appears to be in good shape-no visible damage. I assume the gas flame height is ok since the pressure is 11.2". There's no yellow color in flame.
In my mind, the thermistor is ruled out as well as the thermostat since AC cooling works. However, a faulty thermostat haunts me??
Is a dirty flue possibly the cause of poor propane cooling, especially in the frig section? On the Casita, I'll have to drill out 18 rivets attaching the upper cooling vent in order to get to the top of the flue.
Any thoughts or comments would be most appreciated.
yolofitz is offline   Reply With Quote
Old 09-28-2014, 05:59 PM   #2
Yes a dirty flue or burner could cause the problem and sadly I need to do the same to get at the top of flue on my Scamp as well...... they do not make it easy.
I have found on mine that it does not run well when set at MAX when on propane - better at about 5 - perhaps one or two higher in real warm weather. If set at Max the freezer tends to freeze up which does interfere with fridge performance on propane.
propane
Dometic RM2202 Fridge Problem...won't get cold on propane but DOES Jeff G. Problem Solving | Owners Helping Owners 24 09-24-2014 07:48 PM
Slow cooling steve dunham Problem Solving | Owners Helping Owners 5 06-23-2012 02:05 PM
Fridge not cooling correctly Matthew A Problem Solving | Owners Helping Owners 21 08-03-2011 06:43 AM
Dometic fridge cooling unit replacement TonyB Problem Solving | Owners Helping Owners 2 07-25-2008 06:34 PM
Cooling fan for an Icebox? Mike Montville Problem Solving | Owners Helping Owners 8 03-28-2008 04:49 PM
