Dometic DM2852 - Fiberglass RV
Old 11-04-2019, 06:11 PM   #1
Trailer: Bigfoot 25RQ
Mississippi
Dometic DM2852
While checking my refrigerator today the red check light came on. From reading the instructions this is only supposed to happen when running on propane, I'm running it on AC. I run my fridge and AC at least once a month just to keep things working or to find these little surprises before going on a trip.
This unit is 15 months old.
On the plus side we have logged almost 10K miles on our camper on our last trip in Sep.
Any suggestions on the fridge or why this light is on when it shouldn't be?
snuffy2 is offline   Reply With Quote
Old 12-05-2019, 05:22 PM   #2
Mississippi
Ok
All these views and no replies.
Old 12-05-2019, 05:45 PM   #3
Haven't seen the check light on my fridge except when I was on propane and there was air in the line. Once the line was bled (by lighting the stove multiple times until it came on) the check light went out.
Sorry, never seen it on when using AC. That being said, have you checked the breakers and fuses?
JonRaw is offline   Reply With Quote
Old 12-06-2019, 10:10 AM   #4
tractors1's Avatar
Trailer: Escape 21 - Felicity
Check light only comes on when a gas failure-to-light occurs. You must turn the fridge on & off to reset.
From page 6 of the Dometic manual:
"Should 120 VAC become available while the CHECK indicator lamp is on, the
CHECK lamp will not turn off until the ON/OFF button is pressed OFF and then ON again"
Charlie Y
Old 12-07-2019, 09:45 AM   #5
Mississippi
Yep
The fridge won't do anything when gas is chosen. No igniter, no gas flow nothing. Runs fine on SP -7F in freezer 27F in fridge. When going to gas the check light comes on and stays on, doesn't try to ignite. Check light will stay on when switching back to SP unless I unplug the fridge and plug it back in. Other thing is when on SP and check light on the internal light doesn't work when you open the door. Already checked the eyebrow panel.
Yes I read the manual front to back.
Old 12-07-2019, 09:53 AM   #6
widgetwizard's Avatar
Do you have a good battery?
Sounds like your 12V is missing....
Retired from Orbital Machine Works.
Where is Jim now?
widgetwizard is online now   Reply With Quote
Old 12-07-2019, 10:38 AM   #7
Mississippi
Yes
12 Volts is there. Friend of mine is bringing another eyebrow board from his unit. I replaced that with a new one but still didn't work. He knows his is good so we are going to try that in desperation. He will be here in about an hour, well see.
Old 12-07-2019, 11:55 AM   #8
Mississippi
OK
Problem solved, we put a different eyebrow board/panel on the fridge then the propane fired right off. Seems the new one from Amazon is also faulty so I'll send it back to get a replacement. Good thing it's not an expensive part!
Old 01-02-2020, 11:50 AM   #9
Mississippi
Again
Well we are right back where we started. Check light on with AC power or gas. Will not clear will not run on either one. I can't believe I have gotten two bad eyebrow boards from dometic. Well try to trouble shoot again.
Old 01-02-2020, 04:08 PM   #10
Everywhere
I would check the voltage on the incoming 12V power and make sure all the connections are clean and secure (including on the fusebox side of things). That's basically the remaining common denominator in all the things going wrong.
Old 01-03-2020, 10:29 AM   #11
Mississippi
volts
At the circuit board I have 13.4 volts at the terminal block, 13.4 volts coming out to the circuit board display and 13.4 at the eyebrow board. Is there anything else that would stop 120V and 12V from working except the circuit board or brain as some say.
Old 01-03-2020, 10:32 AM   #12
Mississippi
Blue wire
There is a blue wire coming out go the circuit board that's is labeled test. Is this just to test power as I did by using the connector for the display panel or eyebrow board?
Dometic parts needed Sharon Herman Problem Solving | Owners Helping Owners 1 11-15-2005 01:12 AM
Lighting the Dometic Legacy Posts Problem Solving | Owners Helping Owners 28 08-11-2003 01:29 PM
Dometic fridge front panel Legacy Posts Problem Solving | Owners Helping Owners 5 05-06-2003 10:04 PM
Dometic Refer Hinge Problem??? Legacy Posts Problem Solving | Owners Helping Owners 0 10-14-2002 07:38 PM
1-800-call Dometic Legacy Posts Problem Solving | Owners Helping Owners 1 10-11-2002 08:23 AM
