Dometic Fridge - Fiberglass RV
Old 07-26-2007, 01:07 AM   #1
Hi
I have aquired a 1970 Trails west Campster that has been re- fitted with a "newer" Dometic fridge which is about 10 years old. (model 2202)
The fridge has not been run for over a year. When I try to use the LP source then I depress the gas valve and manual igniter to light up occasionally I get a brief flame up but the burner light does not stay lit. I have coursed through the fridge manual with no luck, any ideas on what is happening?
The fridge works fine on 120V
Atma is offline   Reply With Quote
Old 07-26-2007, 06:54 AM   #2
Suz
Suz's Avatar
Hello, Atma
Sometimes, when they haven't been on propane for a while, there is quite a bit of air in the lines. The best thing that I have found is to turn your stovetop on and leave a burner burning while you're trying to light the fridge. It should light up pretty easily after that.
NOTE: This can also happen when you turn the propane bottle off before you turn off the fridge.
Suz is offline   Reply With Quote
Old 07-27-2007, 10:32 AM   #3
Trailer: 1978 Boler
One thing I found out the hard way on my 1978 boler: the thermocouple has to be positioned well into the pilot flame. You would think the thermocouple would burn up but, it doesn't.
My main burner would not stay lighted until I repositioned the thermocouple well into the pilot flame.
Believe it or not, I think it had been like this from day one. My trailer also had some 12v wiring errors that I corrected.
Russ is offline   Reply With Quote
Old 07-27-2007, 10:47 AM   #4
Trailer: Scamp 16 ft
you may want to inspect the venturi for spider eggs and webs. they like to do that to gas grills.
Dan B is offline   Reply With Quote
fridge
Dometic Fridge James Cooke Problem Solving | Owners Helping Owners 4 05-06-2010 06:59 AM
dometic fridge Paul from NWOnt General Chat 0 08-12-2007 06:57 PM
Dometic fridge Paul from NWOnt General Chat 7 08-08-2007 08:40 PM
Dometic Fridge bdiscount Problem Solving | Owners Helping Owners 12 06-26-2006 01:01 PM
3 way Dometic fridge Laura Heiman Classified Archives 0 03-31-2006 10:14 AM
