I have noticed that my "lit" meter indicator is not working although the unit does
light and the burner does stay lit. My gut feeling tells me that it is probably just a loose connection from the meter to where it attaches at the coupler point or ground and picks up the minute voltage. Its rare that I have seen meters go bad. With that being said, it looks like its is a bear to take the
fridge far enough out to where I can look down at the top of the unit and verify the connections. Once its out I can check voltages and meter function if needed. I don't see a part number for that small meter anywhere.
Has anyone suffered the same issue? Anyone slipped the
fridge out? RM2543 3 way.
I was thinking out loud that I could put in another extra thermocouple sensor and then figure out a circuit to snake up through the cabinet and show an LED lit or something rather than try and remove that puppy. Perhaps have a relay ckt powered up to drive a red or green super LED.
Any thoughts or suggestions?
THANKS
