Dometic 'fridge vent - Fiberglass RV
Old 07-16-2007, 08:43 AM   #1
Trailer: 1991 16 ft Casita Freedom Deluxe
When I got my Casita, there was a length of approx. 1" corrugated foil and paper tube laying in the bottom of the area where the burner controls are, behind the outside door. It appears that it may have come from the top of the chimney at one time - what is the purpose of this tube, and where is the other end of it supposed to go?
Sorry, I don't have the model number of the fridge handy, but it's one that Dometic does not have the owner's manual online at the current time. I can check when I get home tonight. It's a small one with a teensy freezer, no storage in the door, and it's DC and LP only, no AC operation.
It seems to work OK on gas, I haven't tried the DC yet.
Thanks!
Lee Hillsgrove is offline   Reply With Quote
Old 07-19-2007, 09:59 PM   #2
Well, I'll answer my own question, in case someone else runs into the same thing in the future.
I have a RM2190 refrigerator. I found a service manual online (then discovered we had the same one in the document center) which describes it as a "balanced flue tube". It looks like it is supposed to extend up from a round hole in the rectangular box which surrounds the burner, parallel to the flue tube, to end near the crossover tube. The manual makes mention that if the opening of the balanced flue tube is too close to the crossover tube, that flame outage could occur.
I know my refrigerator seemed to work OK without it , but I'll likely try to reinstall it, and I'll post here if I find anything unusual or notable when I do. I also need to get a few screws as the entire refrigerant coil assembly with the burner attached is loose relative to the chassis of the refrigerator. I'm guessing that the vibration from going down the road has shaken them and the balnced flue tube loose. I know that when I bought the trailer the tire on that side had been replaced by a spare because it had failed, and the one on the other side (which it had been towed on) showed severe signs of belt failure - the tread had separated, you could see the cords through the resulting fissures in the tread, and half of the tire had taken on the rounded profile of a motorcycle tire. At least the thrashing didn't cause the refrigerant coils to fail.
Old 07-19-2007, 10:08 PM   #3
Administrator
Mary F's Avatar
Thanks for posting that info, Lee!
Mary F Fiberglass Rules!
FGRV Forum Custom Search
RV Life Network FAQ
fridge
Dometic Vent Bud Kennedy Problem Solving | Owners Helping Owners 2 01-30-2010 03:10 PM
dometic fridge Paul from NWOnt General Chat 0 08-12-2007 06:57 PM
Dometic fridge Paul from NWOnt General Chat 7 08-08-2007 08:40 PM
Dometic Fridge Atma Problem Solving | Owners Helping Owners 3 07-27-2007 10:47 AM
3 way Dometic fridge Laura Heiman Classified Archives 0 03-31-2006 10:14 AM
