dometic frig fire, help - Fiberglass RV
Old 08-12-2010, 07:52 PM   #1
sugermc's Avatar
Trailer: 1983 13 ft Scamp and 1985 13 ft Scamp
Hi, we've been working hard this week, getting ready for the "Tacky Tour" of Minnisota, spent a ton of time with the 3-way frig
When we first got the Scamp home, just plugged the frig into 110 and let it sit for a few days, found out it work - cool I said
Went straight to work to build a custom cabinet for the frig - great, going good.
Finished cabinet, then started to work on the LP lines, decided to split source at tank and have a 14' rubber line with a quick disconect for cooking outside.
The other line was going to the frig. decided that before I put frig in hook this baby up and see how she goes with LP --- NO WORKIE
It takes gas and the pilot shows gas BUT!!! when you release the button, no gas UUUGGGHHH.
Adrian snoops around and see's, what we call a thermal-couple line that has a crack, call Dometic, they send part - Cool I said , beer will be chilled on the tour
Install part - NO WORKIE
Then, superstar Adrian, decides at the button, this valve must be broke, call Dometic, can not confirm arrival of part before we leave
Then Adrian says, what do I have to lose, he takes the thing he was going to replace, takes it apart, see all kinds of gunk, cleans it, put it back on and LO-AN-BEHOLD WORKIE !!!!
Well Cool I said, lets do a test drive on this baby, read the book, see that if the ambiant temp is above 80 degrees, leave on HIGH, (and its 98 here in TN) OKAY high is, let the test begin.
I hour temp inside frig, was 98 drops to 68
Decided that maybe a box fan place away from the front but blowing toward it would reduce outside temp a little, seemed that vent was a little hot, might make the test go better
Go up to barn, check water on the critters and such, 25 min max
Come back The FRIDGE IS ON FIRE!!!! and hooked up the the LP TANK!! YIKES
Turned off the LP, dumped water on it, NOW no type of fridge for the trip
What could of cause the Fire??? MASTER, Harry Young, any ideas?
And now I need to be told how to travel for 15 days with no fridge and work out of coolers, I know picking up ice can be done dailey, but maybe you camping pros have some tips Thanks Suger
sugermc is offline   Reply With Quote
Old 08-12-2010, 08:50 PM   #2
Matt in SV's Avatar
Trailer: U-Haul VT16
Sounds like the hot vent might mean some obstructed circulation. also, you might have had a leak through a loose fitting or cracked hose. Did you try spritzing all the unions with soapy water before lighting it?
Regards,
Matt
Planning our next Escape!
Old 08-13-2010, 12:10 AM   #3
Brian Van Snell's Avatar
Trailer: Escape 13 ft 2010 ('Ladybug') / 2003 Subaru Forester
supermc:
Our Dometic fridge was not cooling adequately this summer when we hit some hot weather so we bought a 36 qt Coleman cooler which claimed to keep ice for 5 days. We bought one, and it worked. A similar cooler might provide a short term solution for you until you can get your fridge going.
Brian
Brian & Maria
2010 Escape 13 "Ladybug"|2003 Subaru Forester|2012 Toyota Highlander
Brian Van Snell is offline   Reply With Quote
Old 08-13-2010, 04:54 AM   #4
sugermc's Avatar
Thanks Matt, the vent is clear but would you mean the piping with the amonia going thru? Would not know how to check that, did check the union fittings though, didnt look to have leaks
I was looking at those extreme coolers, glad to hear from some one that it works. Thanks for your help suger
Dometic RM2410 Frig problem Duncan B. Problem Solving | Owners Helping Owners 0 08-02-2010 09:26 AM
Frig venting sugermc Problem Solving | Owners Helping Owners 3 07-18-2010 05:26 AM
Frig. Temp. Kevin K Problem Solving | Owners Helping Owners 5 08-22-2008 05:08 PM
Propane Frig Kevin K General Chat 5 04-29-2008 09:37 PM
Fire, Fire Everywhere & No Volunteer Fire Dept Raunie Aasland General Chat 2 11-24-2006 09:05 PM
