Hi All,
Any thoughts on the following
refrigerator problem. We driveway camped a couple of weeks ago in our new to us '05
Casita 17' FD. I turned on the
refrigerator and used a wireless thermometer. By the next morning, the
fridge was in the upper 20s and the freezer 5 below zero with the setting on 5 (coldest) using 120V shorepower. Nice!
I tried a time or two to use
propane, but after two or three times of it clicking no ignition even though the
propane was on and both the stove and WH were working fine. I assume something is dirty and needs to be cleaned.
OK for my bigger problem. We used the
fridge for two days in the driveway adjusting the setting to 2 or 3 with lots of success. We then left to go to the local KOA for a shakedown night. Even though I didn't need to do this, given our short distance, I turned the
fridge on DC power. It switched over per the display
light. However, once we got to the campground, the fridge had stopped working and has had no power since??? I think I have some type of
electrical problem.
I have checked the blade fuse in the mainbox under the driver side dinette. Looks good. I checked the blade fuse in the external lower compartment that is in the wiring. Looks good. I removed the power control module cover and both glass fuses look good. It does not appear to be a fuse??? Also, my fridge has an external cooling fan that runs off a toggle switch located in the upper left hand corner as you enter the
Casita. When the toggle is turned on, the fan would run and the toggle would glow red. The external fan is not working as well including the red
light on the toggle switch. It appears to me that the unit is getting no power. Also, I checked the outlet that powers the fridge. It is working fine.
Any thoughts before I head to the local Camping World?
Thanks,
Dean
