Originally Posted by mensie
I had some time to fiddle around with the fridge again, it turns out that it works on propane but not on electric so that tells me that the heating element is toast.
Anyone knows where to get a new one? and is it easy to install?
Most RV dealerships would have one of the 110 elements. Easy to install
Did you check the chiminey flue, is the spiral ribbon piece hanging from a wire? Also a good idea to vacuum off the dust and that from the tubes at the back of the fridge and blow some air around the chimney. Small spiders and flies love the smell of
propane and love to crawl inside of the chiney. Wasps do too.
If you are going to dumble the fridge, you have to turn it from side to side, not front to back, just keep rolling it over. One roll, leave it for awhile, then another roll. Not complete rolls just 90 degrees at a time
