Dometic rm2354 fridge door - Fiberglass RV
Old 02-07-2018, 09:08 PM   #1
Trailer: Escape 17b 2006
Traveling in Southern California and my door has broken off at the hindge. Does anyone have a door or a fix?
2006 Escape 17b
Grant Allen is offline   Reply With Quote
Old 02-08-2018, 08:28 AM   #2
RV Doctor George in Sacramento might have a used door. There are other suppliers of used parts too. If you have to contact Dometic, be sure you are sitting on the floor when you phone them. Sitting on the floor is the safest way to make this call. You can't fall off the floor, and when Dometic tells you the price of the replacement door, you most likely will collapse.
Jack L is online now   Reply With Quote
Old 02-08-2018, 11:06 AM   #3
Replacement hinges are available
Try pantherrvproducts.com
Stevieboy is offline   Reply With Quote
Old 02-08-2018, 11:28 AM   #4
Little House Customs dot com has fridge door hinge reinforcement parts which work for the Dometic fridges they put in Casitas. You could contact them and ask if they would work on your fridge. I'm sure the price is much more reasonable than Dometic's
Morgan A is offline   Reply With Quote
Old 02-08-2018, 05:25 PM   #5
Trailer: G30 Elite Class C
2006 Escape 17b
contact the manufacturer and see if the can UPS parts to repair it?? If they can make sure you find out how long it will take for them to get the parts to u.
Stude
stude is offline   Reply With Quote
Old 02-16-2018, 07:16 AM   #6
Trailer: 1999 Casita 17' SD
Ohio
Morgan is 100% correct, Dometic thinks very highly of their parts
I don't know if Larry's Little house plate will work on your door but here's a picture of it on my older Dometic.
It's fantastic as a preventative measure and might rescue your door.
Joe
Old 02-24-2018, 08:22 PM   #7
Trailer: 1977 17' Boler
Saskatchewan
Well I too have the the same RM 2354 fridge in my trailer. Was told by a good friend that the door hinges do break or crack as did yours. The main cause I was told was placing heavy objects in the door shelf and just the weight on the door and the vibration from the road causes this.
Will my fix was to place a support under the non hinged side. But what? Well I order the lower hinge foe the open side of the door. This part would be needed if the door was to open the opposite way. After the hinge was installed the weight of the door rests on the hinge support. There is also a hole in the bottom of the door that aligns withe the hole in the hinge. I found a pin and a long elastic and now more door won't jar open as well and no stress on the other door hinges.
Greg Boler77
Boler77 is offline   Reply With Quote
Old 02-24-2018, 10:33 PM   #8
there is a large used rv dealer parts guy in carthage mo he strips out wrecked trailers!
bob
fridge
Replacing RM2354. Dometic / Norcold? Nik Modifications, Alterations and Updates 26 02-16-2018 01:41 PM
Freezer door for Dometic 2201 fridge Loriski Problem Solving | Owners Helping Owners 0 09-16-2014 12:48 PM
Wanted: Dometic Fridge Freezer Door hajnfur Parts: Buy | Sell | Trade 0 07-31-2012 04:59 PM
Freezer door for Dometic 2201 fridge Carol H Classified Archives 3 08-30-2011 11:27 AM
Boler door hinge repair kit and fridge access door John Jesse Problem Solving | Owners Helping Owners 5 05-27-2011 12:32 PM
