Donuts? - Fiberglass RV
Old 03-28-2013, 08:13 AM   #1
Trailer: 2015 Scamp 16' deluxe 2008 FJ Cruiser
Donuts?
Having a teardrop and an old Scotty I have not had to think of waste water. Now having a Scamp on order so things are coming up. First what is a donut that some campgrounds require for the black water? I have seen a funnel looking thing that goes in the ground on the end of the waste pipe. I just found out my trailer will have two seperate waste hook ups do I need a "Y" with two pipes for one sewer connection? Hoping someone can make this simple for me.
Ken
Ken in Pa is offline   Reply With Quote
Old 03-28-2013, 08:17 AM   #2
Trailer: Bigfoot, Trillium, Scamp 5th Wheel
Spokane Wa. and Las Vegas, Nv.
You will have 2 drains. One for the blackwater under the toilet which you will drain first and one under the back for your grey water which you will drain last. The reason for draining the grey water last is so it can rinse out the drain hose (sort of lol).
Old 03-28-2013, 10:01 AM   #3
cpaharley2008's Avatar
here is a "donut", a device to keep your sewer pipe inside the connection
Camping list
Old 03-28-2013, 10:38 AM   #4
So a donut is just a weight to hold down the hose? What about the soft rubber looking funnel I saw? I wonder where I am going to stick all this junk. The Scamp has no cargo doors and they will not install one that may be one of my first mods. I can wait on that one.
Ken
Old 03-28-2013, 10:58 AM   #5
The donut is what keeps the hose connected to the sewer, supposed to be air tight, in addition you may need some weight to keep it in place, not sure what is under the picture as I do not not own one, but you fill this with water to keep your hose in place, you probably need a separate donut under this to seal the opening.
Old 03-28-2013, 11:08 AM   #6
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
Google "rv sewer hose seal" and you'll get adapters and elbows+adaptors and what all including no doubt water-filled pink pigs along with assertions that they seal against odour transmission or leakage. Get the donut for a couple bucks at Walmart or whatever. I'll bet any campground or park which requires a waterproof seal will have one available in the camp store for $35+. I have not encountered a state park, KOA or other private rv park which does but don't doubt that day is coming. Sht happens.
jack
Old 03-28-2013, 11:15 AM   #7
rabbit's Avatar
Delaware
http://www.campingworld.com/shopping...ewer-seal/4496
This one qualifies as a "seal" according to CW.
Old 03-28-2013, 12:05 PM   #8
Thank you everyone
Ken
Old 03-28-2013, 12:27 PM   #9
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
I've never paid attention to this area of Scamps but although you have 2 gate valves don't they continue on into one 4" outlet? Or do they actually have two gate valves AND two outlets and the hose has to be switched between them when draining?
Old 03-28-2013, 06:38 PM   #10
Yes, Scamp has two gate valves, they're not connected. There will be a "stinky slinky" mounted in a tube to the front of the trailer (FUGLY looking thing), a sewer connector is provided (threaded). The gray water tank MAY have a (garden) hose connector on the outside of the cap. The only time a rubber donut is needed is if the sewer doesn't have a screw thread... the threaded connection provides a complete seal.
Old 04-01-2013, 05:45 PM   #11
Trailer: '79 Boler 1700RGH
Donuts are for sewer hookups with no threads.. these are pretty rare from what i've seen anyway.
Usually it's a PVC pipe hookup, requiring one of these:
Camco 39144 Quikslip Sewer Elbow - Walmart.com
Boleroleroleroleroleroleroler
Kinslayer is offline   Reply With Quote
Old 04-01-2013, 06:50 PM   #12
Everyone who has a sewer hookup at http://www.fiberglassrv.com/forums/f...may-53819.html needs to bring a donut!!! The sewer connection is a 90 degree and is NOT threaded.
Old 04-01-2013, 06:59 PM   #13
I'm trying to understand.
Is this donut device required by some parks ( not many ) and would the park police only notice if you were one of those campers who leave the slinky in the dump for their entire stay?
As in, I only dump when the black tank is close to full, even in a full service camp. So, I'm likely dumping because I'm heading somewhere else. They are going to have to catch me in the act then? And, then they kick me out?
Old 04-01-2013, 07:05 PM   #14
I know first hand from camping at Maryhill there is no way to get a seal without a donut. Whether you're draining graywater or blackwater... it leaks on the ground . Rather than the connection being flat on the ground, it's a raised 90 degree pipe. Don't know why they did it that way, it can be a mess.
