Dook Lock Scamp Stuck - Fiberglass RV
Old 07-27-2011, 11:36 PM   #1
Trailer: 1977 Scamp 13 ft
I am trying to replace the door lock on my 13 foot Scamp. I remove the two screws on the outside first. Then I remove the 6 screws on the inside but it still would not come apart, It will spin around on both sides but would not come apart. I tried hitting the center square pin but that did not seem to help. Any idea's would be appreciated. Thanks
Norm
Norman Milliard is offline   Reply With Quote
Old 07-28-2011, 09:12 PM   #2
IllAnnoy
Norm
I used a 4" grinder with a cutoff wheel on one like you describe.
You could use a wheel puller or a slidehammer or soak it in a good penetrating oil then wiggle the inside mechanism with a channel locks.
if you look closely you will see that the inside part is sandwiched at the point where it meets the door... Drive a screwdriver in between the two layers and pry it apart.
Hacksaw the square shaft on the outside of the door.
Old 07-29-2011, 03:22 PM   #3
success
I pounded on it for a while then when gap was big enough I use a reciprocating saw. So it is now done and works well. Thanks the help Floyd
NEW Scamp lock/handle and striker plate highlandsgirl Classified Archives 1 12-01-2010 08:29 AM
Query about door lock to lock from inside sara maccalman Problem Solving | Owners Helping Owners 4 11-14-2010 06:11 AM
What's a good coupler lock for a scamp 13 bcomnes Care and Feeding of Molded Fiberglass Trailers 8 01-26-2010 09:37 PM
Scamp Inside door lock? Sheryl M Problem Solving | Owners Helping Owners 5 10-07-2007 07:17 AM
Removing door handle and lock on 13' Scamp Gary Little Problem Solving | Owners Helping Owners 14 02-09-2006 07:58 PM
» Trailer Showcase
Bean
Vickie B.
Scamp
chefjj
