There are several common ways a door can fail to fit properly on an older trailer. There is no adjustment, but there are fixes. If the hinges are sagging but otherwise still solidly attached to door and trailer, these
Hinge Rebuild Kits sold by member Ian G. might be all you need.
If the hinges are loose, or if there is a large gap at the bottom, the solution could be more involved.
Pictures would help.
