Door fit + frame flex/failure - Fiberglass RV
Old 07-18-2017, 09:00 AM   #1
Johnny M's Avatar
Deep South
Has anyone noticed the door fitting/closing differently when stabilized/leveled vs when hooked to the tow? I have had an on going issue with my Boler of this and despite adding significant wood tabs fiberglassed to the interior shell and anchoring the wood closet/roof support to it in order to stabilize the body from flexing I still notice the body around the door shifts enough to make the door difficult to latch depending on whether in tow or level/stabilized.
If I have to significantly level the camper front to back or side to side it is more noticeable. I think the original frame may be flexing. I have inspected the frame and can find no cracks or stress signs anywhere typical to Bolers/Scamps (except as noted in the last paragraph), mine even has extra reinforcement in the stress points. I have new wood floors installed and glassed to the body in 2015, plywood tabs glassed around the door (left and right), the right side of closet and tabs on the street side that cabinets and bath wall anchors too to support the roof. The floor is bolted (x4) 2 in the rear and 2 in the front with additional self taping screws through the floor into the frame. So if the frame is flexing so is the floor and the body. The door has been completely rebuilt with a metal frame inside so the door itself does not flex like some doors known to have fit problems. It even did this with the original old fiberglass fixtures riveted as well and I now suspect was the cause of some failed rivets around the closed and other areas, so I don't suspect it has to do as much with my wood that replaced the fiberglass as it does a weak frame.
Also, this weekend on the way home, the rear bumper failed at the point where the bike rack receiver hitch is welded to it. The welds held up but the bumper cracked/broke above where the weld bead is causing the the receiver to bend to the ground dragging the bike rack (2 adult bikes and a kids bike). Luckily it happened in the GSM National Park (Cataloochee) on a dirt road and we were going slow when it failed. I think some washout/pot holes stressed it causing it to break. We managed to carefully get the bikes & rack inside the camper for the ride home. It towed fine before this failure with no sway or handling issues. Upon closer inspection we noticed the inside of the tubular frame has some significant rust. I knew the frame was of thin metal but was really shocked by how thin the frame actually was. My bbq grill is made of thicker metal! When I had the body off 2 years ago I found very little rust (surface) on the outside, sanded/wire brushed to bare metal, primed and painted.
Now I am planning for a new stronger frame made out of a heavier gauge steel, but am contemplating what gauge steel to go with. I have a #9 Dexter setup for 1800-2000 lbs, before the axle the trailer was 1440 dry.
1971 Boler 1300 - "Suite 13"
1987 Play-Mor II - "The Beach House"
Old 07-18-2017, 10:11 AM   #2
We noticed too that "the door fitting/closing differently when stabilized/leveled vs when hooked to the tow".
HawkBoler72 is offline   Reply With Quote
Old 07-18-2017, 12:27 PM   #3
Johnny M's Avatar
Deep South
Is your Boler stock like it came from the factory or has it been extensively modified (structurally)? While I hope you don't have problems, it is good to know that it is not just mine with this issue. After researching about trailer frame construction specifically regarding flexing and steel frame gauge I came across the following article (see the link down below) I found very informative, particularly the part about Torsion axles. Here is an excerpt about that in particular:
"Torsion axles add a lot of extra stress on the frame at the attachment point. (Load is both vertical and torsional.) Itís OK, as long as the trailer builder accommodates the added loads. However, if the frame is not reinforced where a torsion axle mounts, itís a sure sign of weakness."
In addition, on our trailer and others I have seen, it seems common to weld short beads in several spots rather than one continuous weld, again another sign of a weak point for trailers like our eggs. It surprises me somewhat that back in the era ours was built in (71) that the overall quality of the trailer was built to last generations compared to a stickie, yet the frame which serves as the foundation of these cool eggs are somewhat poorly designed. Even with light weight trailer design in mind they could have used a stronger frame without significantly affecting the overall weight.
https://www.synthx.com/articles/trailer-strength.html/
Old 07-18-2017, 01:50 PM   #4
The frame was reinforced with 2"x 2" steel beam at front. When leveled, I use additional support at the bottom as shown in the pictures.
Hopefully, no problem.
Old 07-18-2017, 03:19 PM   #5
Johnny M's Avatar
Deep South
Mine has some gussets welded in the weak spots which Ian G points out as potential failure areas. If you look close you can see these welds are incremental and do not go all the way across the seams (weaker than complete seam welds). These were in place when I got it but I believe they were added post factory. But this doesn't do much for the trailer flexing side to side or front to back. There is no reinforcement anywhere else, just the standard frame as commonly known here on the forum.
One thing mine does seem to have that others don't is once piece tubing from the coupler past the bends under the front floor, I have seen seams in these areas on other trailers.
Old 07-18-2017, 03:43 PM   #6
Johnny M's Avatar
Deep South
Here is some pics showing the break in the frame/rear bumper above the weld on the bike rack hitch. Notice the significant rusting inside the opening of the frame tubing.
Old 07-18-2017, 03:50 PM   #7
Is some kind of 'bends' may be not avoidable? Just don't exceed the limit (what is the limit?).
Sometime, I may add the piece as shown in your second picture.
Old 07-18-2017, 03:52 PM   #8
That's not good. I guess the welding wasn't done very well. I try to avoid adding anything on the rear bump.
Old 07-18-2017, 04:35 PM   #9
Thanks for showing us these pictures. This just one more reason to NOT carry bicycles on the back of one our trailers.
Old 07-19-2017, 07:21 AM   #10
Johnny M's Avatar
Deep South
Eric, I am no expert welder but have been learning from a friend who is a professional welder by trade. While my welds don't look textbook pretty, they penetrated the metal of both the bumper and the hitch. I used 6013 rods and multiple passes to ensure the strength of the welds. If you look close at the photos you can see the welds did not give, but rather the metal of the bumper cracked in to above the welds. My welder friend is out of town but he is going to take a look at it on Thursday for me, I will post what he says when he sees it...
Old 07-19-2017, 07:28 AM   #11
Johnny M's Avatar
Deep South
Byron, I agree with you regarding the original lightweight frame construction. I knew it was a thin metal frame, but I honestly didn't know it was that thin. I also think it was weakend by the hidden rust on the inside of the frame. I have owned bbq grills made with thicker metal! With that said, the replacement frame WILL be stout enough to hold the receiver/bike rack and should not flex allowing for a more stable body/door fit regardless of whether hooked to the tow or leveled/stabilized...
Old 07-19-2017, 08:54 AM   #12
Johnny, I'm sorry to hear about your hitch mount frame failure. It's a good thing you caught it that quickly.
I'm a proud owner of a 71 Boler too but it looks like I was lucky to get one built earlier than yours. My frame appeared to be quite solid when I pulled it out to check it and modify it for my new axle. I've never been up close to one of the later frames but from pictures I've seen they do seem to be built with pretty thin walled tubing. Mine is all C channel of a decent gauge (no bumper).
That didn't stop me from adding some additional strength. I added 2x4" box tubing under the rails to support the new axle. I had to have something there to allow the switch from a leading to a trailing axle so I went ahead and ran it longer for more support. I also added C channel under the typical failure spots where the frame bends toward the tongue. I ran that long up toward the front too. It was likely a lot of overkill and extra weight but it makes me feel better. I've never noticed any of the door area flexing you mentioned.
I have a receiver on the back for a bike rack too and it's awfully nice to have there knowing that it's solid. I'm guessing you'll be really happy with yournew frame once you get it built.
Russ
RussL is offline   Reply With Quote
Old 07-19-2017, 09:53 AM   #13
Bruce Thomas's Avatar
Trailer: Hunter compact jr
Indiana
I see so many frame structure problems on here that I wonder if there's a market for frames. Isn't like any of them are hard to copy, esp with better materials.
Bruce Thomas is offline   Reply With Quote
Old 07-19-2017, 10:57 AM   #14
You have to evaluate what you want your stabilizer jacks to actually do in application. You will need a far stronger structure in the frame if your asking the jack to lift and level as opposed to stiffen to stop the wiggle of the suspension. All of the small frame fiberglass trailers I have seen are not strong enough for lift and level. I feel most frames do not have the proper structure to support the leverage of a bike rack hanging off the back.
If I was building a new frame I would build in designated jacking points for an axle jack for changing the tire especially if your using a torsion axle. I would also double the frame thickness to make rust out from the inside of the tube a thing of the past and to severely stiffen the chassis. But I don't have to worry about weight because my choice of tugs can handle the additional weight. I would paint the inside of the tube before I cut and welded up the tubing to make a frame. Maybe even a better option would be using C-Channel since you wouldn't have internal failure.
How much flex should a torsion axle flex, if a torsion axle could flex flex? JeepScamp Problem Solving | Owners Helping Owners 5 08-10-2014 05:03 PM
Scamp 13 Lower Door Hinge FG Flex CampyTime Problem Solving | Owners Helping Owners 0 05-20-2014 05:53 PM
Solar related Q: flex power mat? jen b Care and Feeding of Molded Fiberglass Trailers 27 04-28-2011 04:30 PM
towing with Ford Flex AWD? artspe Towing, Hitching, Axles and Running Gear 2 02-01-2011 06:06 PM
10 watt solar flex mat Dan Simon Modifications, Alterations and Updates 4 08-06-2006 09:26 AM
