Door gap - Fiberglass RV
Old 01-16-2010, 09:36 AM   #1
Vicki A.'s Avatar
Trailer: 2014 Escape 5.0 TA
Now that I have begun to tear my egg apart, I seem to see EVERY little thing I think I need to fix .
My door has quite a gap and as I understand from many posts, this is not unusual. I was wondering tho...is this the way most hinges are on the rest of your eggs? Seems to me it might be necessary (for strength purposes), but isn't this why the door is not flush on the hinge side? I appreciate any responses.
Vicki
Notice the spacer
Vicki A. is offline   Reply With Quote
Old 01-16-2010, 10:18 AM   #2
Bud Kennedy's Avatar
Trailer: 1984 U-Haul / 02 Mazda pick up
I notice that there is a spacer underneath the stationary half.
Would not removing it cause the door to be closer to the opening?
Bud Kennedy is offline   Reply With Quote
Old 01-16-2010, 11:11 AM   #3
Larry&Carrie's Avatar
Trailer: 1983 13 ft Scamp
Send a message via MSN to Larry&Carrie
Talking
Yeah that spacer is very suspect..... Also, the original little brass ball (or what ever it is called-factory installed--) is not there, and if my dim memory is correct, there was a spring involved somehow-- even tho my scamp doesn't have any. Someone has tried to make the door fit better (and not succeeded) at some time.... I suspect that the spacer was put in because when the ball and spring were removed, there was a bind in the hinge, and that was the "quick fix" When I was trying to realign my door, I had the pins too tight and broke a hinge... Larry
Larry&Carrie is offline   Reply With Quote
Old 01-16-2010, 11:18 AM   #4
Trailer: 1990 Bigfoot 17 ft.5 ft
Yes you have the wrong spacer. I would call or order on line through Scamp the the correct spacer its brass . You should just replace the spacers,bolts and nuts that hold both doors. I think there is also a spring that is in that assembly also.
Bill A is offline   Reply With Quote
Old 01-16-2010, 11:18 AM   #5
Scamp sells the ball and spring, here is the link.
http://shop.scamptrailers.com/p-334-door-h...g-nut-bolt.aspx
Bill K
Old 01-16-2010, 12:53 PM   #6
Vicki A.'s Avatar
Can someone send a pic as to what the hinges etc, are supposed to look like?
Vicki
Old 01-16-2010, 02:08 PM   #7
<div align="center">
</div>Bill K
Vicki
Old 01-16-2010, 03:25 PM   #8
Vicki A.'s Avatar
Okay, maybe I didn't expalin this right although I understand part of what I need. What concerns me is that the door doesn't run flush with the shell. Is the hinge(shell part) too long, or is the spacer too much, and do I dare remove it?
Vicki
Old 01-16-2010, 04:27 PM   #9
Talking
Vicki
I would say the spacer was put in when PO removed the ball and spring stuff, and found that he had a bind in the hinge. And then added the shim to overcome the binding.... I would go back to original hinge hardware and see if it works properly. Larry
Old 01-16-2010, 06:43 PM   #10
Vicki A.'s Avatar
Thanks for all of the answers, it actually makes sense to me!!
Thanks again,
Vicki
Bar The door james kent Problem Solving | Owners Helping Owners 13 09-16-2009 11:42 AM
Door Hinges Wayne Boone Problem Solving | Owners Helping Owners 5 04-18-2008 09:05 PM
how to fix door so it won't pop off kimberly Problem Solving | Owners Helping Owners 5 08-02-2006 10:40 AM
Door sag? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 7 08-19-2003 11:11 AM
Door sag? Legacy Posts Problem Solving | Owners Helping Owners 2 07-13-2003 11:55 AM
