Door Gasket? - Page 5 - Fiberglass RV
Old 04-07-2013, 05:41 PM   #57
Trailer: 84 Scamp
West Virginia
Norm, please post a picture of your finished project. I'll bet others would like to see the finished product. Thanks Joe
JDNikirk is offline   Reply With Quote
Old 04-08-2013, 10:15 AM   #58
honda03842's Avatar
Name: Norm and Ginny
Joe, I'll take a picture and post ir tonight
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 04-08-2013, 10:48 AM   #59
Trailer: Bigfoot, Trillium, Scamp 5th Wheel
Spokane Wa. and Las Vegas, Nv.
Originally Posted by Jane D. View Post
Been reading this thread with interest as I need a new door seal. I've looked at lots of links and see different stuff. Can you please specify where you ordered from and possibly the part number??
Thanks much,
Jane D.
I ordered from the ebay link in message #50. It is supposed to be here by Thursday. It was 15 feet and $30 including the shipping. The poster stated that he would have preferred the clamp part to be a bit wider than 1/8 so I ordered the same product with 3/16 wide griping side.
Old 04-08-2013, 01:26 PM   #60
honda03842's Avatar
Gasket Pictures
JD,
I wish I'd asked what you want pictures of specifically. Regardless I took a picture with the Door Closed and the Door Open. If you have a specific picture you want just follow up.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 04-08-2013, 02:23 PM   #61
GMike A's Avatar
I tried to blow up the pictures for clarity of the trim but not sure it worked out well in trying to help or not.
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 04-08-2013, 02:26 PM   #62
Looks like you took the seal completely off the door opening.
Old 04-08-2013, 02:38 PM   #63
honda03842's Avatar
Mike thanks for rotating the pictures.
Steve, I did take the standard foam off the door. The hardest part of the install was removing the foam. I took off as much foam as possible with a knife and than used WD-40 to get off the glue.
I also attached a board below the door to the bottom of the frame to get a really good seal at the bottom. It's hard to imagine that the newer Scamp's wouldn't already have this board to enhance the sealing.
I'll take a picture of the board and the material. The standard black trim around the door also is taken off.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 04-08-2013, 02:43 PM   #64
Did you try mounting it on the opening first? I was thinking of trying it on the opening and seeing if that would work. When I get it delivered I'll look at it and see what the best option would be. As thorough as you generally are I'm sure you must have looked at all the options.
Old 04-08-2013, 02:58 PM   #65
honda03842's Avatar
Mike.
The following is a picture of a piece of the gasket material. I bought it at Autozone but I wish I had purchased it some where else because it was not long enough to do it with one piece.
The second picture is the piece of wood that I attached to the bottom of the Scamp's Floor allowing the bottom of the door to have a firm surface to seal against.
Previously the door sealed above the white board. You can see residual foam above the bottom white board.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 04-08-2013, 02:59 PM   #66
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
A trick I learned in the auto biz, is a way to measure seal gaps (to determine the correct seal diameter). Make little cones from modeling clay and stick them in the critical areas. Gently close the door until it just latches (no over slam). The clay will deform and hold the height once you reopen the door.
Old 04-08-2013, 03:14 PM   #67
Ahhhhhh! Not really possible to mount it at the bottom unless it is installed on the door.
Old 04-08-2013, 05:11 PM   #68
Trailer: 84 Scamp
West Virginia
Norm: Thanks for posting the pictures. I now am clear as to why you needed to add the board at the bottom It really looks nice. Keep us informed as to how it hold up. Again Thanks for the pictures Joe
Old 04-08-2013, 07:18 PM   #69
Trailer: '77 Scamp
Great job Norm. My Scamp needs new weathstripping too. It needed it when I purchased it and the PO knew that and gave me some that he had purchased but hadn't gotten around to. I was going to use it because its free. But after seeing yours, I'm tempted to bite the bullet and use the stuff you used. I like the way it looks and keeps the entry clean and avoids the creeping gasket syndrome.
Otters is offline   Reply With Quote
Old 04-08-2013, 08:01 PM   #70
honda03842's Avatar
Thanks for all the kind words but all the credit goes to Dave Brown.
I will report on how it works for me.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Trillium Door Gasket noah Problem Solving | Owners Helping Owners 16 05-03-2015 08:27 PM
Door gasket question Sharry B Care and Feeding of Molded Fiberglass Trailers 1 05-13-2012 12:28 PM
Door gasket material floyd Care and Feeding of Molded Fiberglass Trailers 13 07-23-2009 08:00 PM
Dometic RM2201 Door Gasket Nate M Problem Solving | Owners Helping Owners 4 06-24-2009 12:29 AM
door trim or gasket Ricky 4 Care and Feeding of Molded Fiberglass Trailers 8 02-08-2009 01:16 PM
