Door Gasket? - Page 6 - Fiberglass RV
Old 04-17-2013, 11:05 AM   #71
Trailer: Chez Nous - a 2011 Scamp 16'
Steve, how did the mount go? You got the gasket right?
SharonM is offline   Reply With Quote
Old 04-17-2013, 11:54 AM   #72
Trailer: Bigfoot, Trillium, Scamp 5th Wheel
Spokane Wa. and Las Vegas, Nv.
I did get the gasket but I've been a little tardy installing it. I'm redoing cabinets,counter tops, doors, flooring, and wiring so it hasn't been a top priority. It looks like it will work real well. I did get the type with a 3/16 gap as some said the 1/8 was a bit too tight.
Old 04-17-2013, 11:59 AM   #73
Steve - thanks for update. I need to get EXACTLY what you got. I'll wait a bit longer to see if you still think it's the best size (3/16 and 15 ft long).
Another question: My foam stuff around the door frame is crappy and has slid around. I need to remove it. There will be goop left behind when I peel it off (I use a plastic blade on stuff like this). Anyhow, Norm said he removed the under foam goop/glue with WD40. Is that the best/most effective stuff to use? Do you know?
Sharon
Old 04-17-2013, 12:04 PM   #74
My Scamp is a 1984 so I'll have the requisite adjusting to do so the door fits correctly first. After looking at the thread about the Escape trailers door gasket I might look at that way one more time. They mount the gasket where the old foam gasket is instead of on the door.
Old 04-17-2013, 12:05 PM   #75
Goo Gone works Sharon for getting it off - just need to put lots on and let it sit awhile. Just make sure you wash down the area really well after.
Old 04-17-2013, 12:13 PM   #76
honda03842's Avatar
Name: Norm and Ginny
Sharon, Like most RVers I always have a can of WD-40. I hust sprayed it on a sponge or paper towel and rubbed a little. I used a knife edge to remove the bulk first.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 04-17-2013, 01:10 PM   #77
Thx Carol and Norm -- I have neither product on hand, so... need to buy.
Old 04-17-2013, 01:22 PM   #78
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
I used "aircraft adhesive remover", most auto stores carry it. I had the door frame cleaned in a couple of minutes. It also worked great to get the 50 taped on hooks off the interior fiberglass.
Old 04-17-2013, 01:26 PM   #79
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Is the stuff at this link what you're talking about, Jared?
I've been trying to remove contact paper glue residue from spots in my trailer ever since I got it!
Francesca
Old 04-17-2013, 01:28 PM   #80
Jared J's Avatar
Kansas
Yep. It's fine on the fiberglass. I would be very careful about getting it on ensolite, and test a spot you didn't care about first.
Old 04-17-2013, 01:31 PM   #81
Fortunately, nobody stuck anything on the Ensolite. But I do also have a couple of leftover ex-glued-hook spots, too.
Glad to finally hear about something that will take it off!
Francesca
Old 04-17-2013, 07:32 PM   #82
If anyone uses the Klean-Strip Aircraft Decal & Adhesive Remover - EAD908 on the ensolite... let us know how it works out! Inquiring minds want to know.
Old 04-17-2013, 09:04 PM   #83
Kansas
I have a can of Permatex gasket remover #4MA that I tried and it worked great for removing the sticky. Just sprayed it on waited for it to stop bubbling and it wiped off cleanly with a rag.
BOBco. is offline   Reply With Quote
Old 04-24-2013, 07:43 PM   #84
Steve, have you tried it yet? I have to choose what I am going to do in the next couple of weeks.
This was a very timely thread for me. Thanks everyone!
ericw is offline   Reply With Quote
Trillium Door Gasket noah Problem Solving | Owners Helping Owners 16 05-03-2015 08:27 PM
Door gasket question Sharry B Care and Feeding of Molded Fiberglass Trailers 1 05-13-2012 12:28 PM
Door gasket material floyd Care and Feeding of Molded Fiberglass Trailers 13 07-23-2009 08:00 PM
Dometic RM2201 Door Gasket Nate M Problem Solving | Owners Helping Owners 4 06-24-2009 12:29 AM
door trim or gasket Ricky 4 Care and Feeding of Molded Fiberglass Trailers 8 02-08-2009 01:16 PM
