Door Gasket? - Fiberglass RV
Old 03-28-2013, 06:54 AM   #1
Steve Hammel's Avatar
Trailer: Trillium 4500
Door Gasket?
I took the old flat foam door gasket off my Scamp and I'm hesitant to put a similar gasket back on. It's an older Scamp and I still need to adjust/fix the door but when that is fixed is there a better product for this purpose? What are some of the alternate gaskets people have used to get a nice seal?
Old 03-28-2013, 09:40 AM   #2
Steve, I am looking at replacing mine as well but I know that Escape uses something different that a few folks with Scamps have used and they say works much better. Sorry I dont have the details on what product its is (I seem to recall it goes around the edge of the fiberglass?). Hopefully someone who has done it will pipe up and give the product details.
Old 03-28-2013, 09:44 AM   #3
honda03842's Avatar
Name: Norm and Ginny
Steve, Search on David B. or sent him a PM. He has a beautiful solution available from a parts store in Apache Junction.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 03-28-2013, 11:05 AM   #4
David B.'s Avatar
The rubber automotive type gasket is simply called "T-2". The place I purchased it from is: SPAGE AGE auto paint store inc.
Mesa Automotive Paint Supply: Products, Refinish, Coating | Space Age Auto Paint Store
Old 03-28-2013, 02:21 PM   #5
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Any product info other than "T-2", David?
I'm not having any luck searching that term alone...
Thanks!
Francesca
Old 03-28-2013, 03:23 PM   #6
GMike A's Avatar
I have searched high and low too as I want that gasket material. Mine was just a basic white wrap around gasket that I had to chuck. I did find this neat site with every gasket size and shape under the sun but if the T2 does it thats great. The website really doesnt show any inventory and I wouldnt know which one to order anyway.
Door Seals | Car Door Seal | Edge Trim | Window Seals | Trunk Seal for car and caravan. Delivery to Worldwide
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 03-28-2013, 05:07 PM   #7
David B.'s Avatar
Thanks!
Francesca
Sorry, but that's what they call it(maybe search for T2) You could call them direct at (480) 835-0971
I initially used it just around the outside of the door itself, but when in the dark and having my wife shine a flash light around the closed door, I noticed light in certain spots. I applied the same T2 around only part of the door opening so as not to have the two interfere with one another.
Old 03-28-2013, 05:19 PM   #8
What does it look like uninstalled? How about a profile shot? How is it installed? Is it just round rubber or does it clip on somehow?
Looks interesting
Thanks
Old 03-28-2013, 06:04 PM   #9
If by "profile shot" Steve means a view of the cut end of the molding itself, I second the request- got a scrap?
And does it fit over the edge of the door so it shows as a black border from the outside?
Thanks!
Francesca
Old 03-28-2013, 06:29 PM   #10
David B.'s Avatar
Looks interesting
Thanks
Steve, Just pull off the original Scamp door trim and replace with the T2. I did have to use a putty knife to get the "rat fur" under the trim in some places. I also glued a 90 degree plastic elbow inside where the two ends met at the bottom of the door. No glue was needed anyplace else, but could be used if it moves around for you.
Dave B.
Old 03-28-2013, 07:41 PM   #11
Nice, perfect pictures, just what I needed. I think it will work. I've seen this before on-line and it sells in 1/4, 3/8, 1/2, 5.8, etc. (tube size). Do you happen to know what size yours is?
Old 03-28-2013, 08:03 PM   #12
David B.'s Avatar
Steve, I used 3/4". What was the name of this "T2" on-line, and what is the on-line link?
Old 03-28-2013, 08:52 PM   #13
I'll have to find it again. At the time I thought it was interesting but without knowing someone who had tried it and the correct size I didn't want to chance it.
Old 03-29-2013, 06:00 AM   #14
GMike A's Avatar
Dave on your picture I am assuming that the bottom trim U shaped was the old gasket and of course the new one I understand. Just didn't know if both were new and you needed both flavors shown in your picture. This is good and will work for me. I can tell from the inside door on mine that there was a water ingress issue.
thanks mucho
Mike
K5NAN
"Miss Adventures"
Old 03-29-2013, 07:08 AM   #15
Haven't found the original location of the "bulk" seal material but here is one similar. I will keep looking because the other site had tons of choices for cheap.
1983 1993 Ford Mustang LX GT Convertible New Door Weatherstrip Seal Each | eBay
Old 03-29-2013, 07:14 AM   #16
Here's another just far more than I need.
New 164 ft Black EPDM Rubber Auto Car Weatherstripping Sponge Push on Gasket | eBay
Old 03-29-2013, 07:17 AM   #17
Interesting read/look.
http://www.enclosurelatches.com/images/gasket.pdf
Old 03-29-2013, 08:29 AM   #18
Thomas G.'s Avatar
Note multiple pages. Once you have the part number, you can search for shorter lengths on eBay, etc.
StanPro - The Right Fit
Old 03-29-2013, 10:38 AM   #19
David B.'s Avatar
Mike, just REMOVE the original and REPLACE it with the T2.
Old 03-29-2013, 10:45 AM   #20
If you are looking for a door seal, why not go to a wrecking yard and dig around in the u-pick are. I bet you can find what you are looking for.
glamourpets is offline   Reply With Quote
Trillium Door Gasket noah Problem Solving | Owners Helping Owners 17 07-30-2020 08:11 PM
Door gasket question Sharry B Care and Feeding of Molded Fiberglass Trailers 1 05-13-2012 12:28 PM
Door gasket material floyd Care and Feeding of Molded Fiberglass Trailers 13 07-23-2009 08:00 PM
Dometic RM2201 Door Gasket Nate M Problem Solving | Owners Helping Owners 4 06-24-2009 12:29 AM
door trim or gasket Ricky 4 Care and Feeding of Molded Fiberglass Trailers 8 02-08-2009 02:16 PM
