Door Gasket? - Page 4 - Fiberglass RV
Old 04-08-2013, 02:23 PM   #61
GMike A's Avatar
I tried to blow up the pictures for clarity of the trim but not sure it worked out well in trying to help or not.
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 04-08-2013, 02:26 PM   #62
Steve Hammel's Avatar
Trailer: Trillium 4500
Looks like you took the seal completely off the door opening.
Old 04-08-2013, 02:38 PM   #63
honda03842's Avatar
Name: Norm and Ginny
Mike thanks for rotating the pictures.
Steve, I did take the standard foam off the door. The hardest part of the install was removing the foam. I took off as much foam as possible with a knife and than used WD-40 to get off the glue.
I also attached a board below the door to the bottom of the frame to get a really good seal at the bottom. It's hard to imagine that the newer Scamp's wouldn't already have this board to enhance the sealing.
I'll take a picture of the board and the material. The standard black trim around the door also is taken off.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 04-08-2013, 02:43 PM   #64
Did you try mounting it on the opening first? I was thinking of trying it on the opening and seeing if that would work. When I get it delivered I'll look at it and see what the best option would be. As thorough as you generally are I'm sure you must have looked at all the options.
Old 04-08-2013, 02:58 PM   #65
honda03842's Avatar
Mike.
The following is a picture of a piece of the gasket material. I bought it at Autozone but I wish I had purchased it some where else because it was not long enough to do it with one piece.
The second picture is the piece of wood that I attached to the bottom of the Scamp's Floor allowing the bottom of the door to have a firm surface to seal against.
Previously the door sealed above the white board. You can see residual foam above the bottom white board.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 04-08-2013, 02:59 PM   #66
Thomas G.'s Avatar
A trick I learned in the auto biz, is a way to measure seal gaps (to determine the correct seal diameter). Make little cones from modeling clay and stick them in the critical areas. Gently close the door until it just latches (no over slam). The clay will deform and hold the height once you reopen the door.
Old 04-08-2013, 03:14 PM   #67
Ahhhhhh! Not really possible to mount it at the bottom unless it is installed on the door.
Old 04-08-2013, 05:11 PM   #68
Trailer: 84 Scamp
West Virginia
Norm: Thanks for posting the pictures. I now am clear as to why you needed to add the board at the bottom It really looks nice. Keep us informed as to how it hold up. Again Thanks for the pictures Joe
JDNikirk is offline   Reply With Quote
Old 04-08-2013, 07:18 PM   #69
Trailer: '77 Scamp
Great job Norm. My Scamp needs new weathstripping too. It needed it when I purchased it and the PO knew that and gave me some that he had purchased but hadn't gotten around to. I was going to use it because its free. But after seeing yours, I'm tempted to bite the bullet and use the stuff you used. I like the way it looks and keeps the entry clean and avoids the creeping gasket syndrome.
Otters is offline   Reply With Quote
Old 04-08-2013, 08:01 PM   #70
honda03842's Avatar
Thanks for all the kind words but all the credit goes to Dave Brown.
I will report on how it works for me.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 04-17-2013, 11:05 AM   #71
Trailer: Chez Nous - a 2011 Scamp 16'
Steve, how did the mount go? You got the gasket right?
SharonM is offline   Reply With Quote
Old 04-17-2013, 11:54 AM   #72
I did get the gasket but I've been a little tardy installing it. I'm redoing cabinets,counter tops, doors, flooring, and wiring so it hasn't been a top priority. It looks like it will work real well. I did get the type with a 3/16 gap as some said the 1/8 was a bit too tight.
Old 04-17-2013, 11:59 AM   #73
Steve - thanks for update. I need to get EXACTLY what you got. I'll wait a bit longer to see if you still think it's the best size (3/16 and 15 ft long).
Another question: My foam stuff around the door frame is crappy and has slid around. I need to remove it. There will be goop left behind when I peel it off (I use a plastic blade on stuff like this). Anyhow, Norm said he removed the under foam goop/glue with WD40. Is that the best/most effective stuff to use? Do you know?
Sharon
Old 04-17-2013, 12:04 PM   #74
My Scamp is a 1984 so I'll have the requisite adjusting to do so the door fits correctly first. After looking at the thread about the Escape trailers door gasket I might look at that way one more time. They mount the gasket where the old foam gasket is instead of on the door.
Old 04-17-2013, 12:05 PM   #75
Goo Gone works Sharon for getting it off - just need to put lots on and let it sit awhile. Just make sure you wash down the area really well after.
Old 04-17-2013, 12:13 PM   #76
honda03842's Avatar
Sharon, Like most RVers I always have a can of WD-40. I hust sprayed it on a sponge or paper towel and rubbed a little. I used a knife edge to remove the bulk first.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 04-17-2013, 01:10 PM   #77
Thx Carol and Norm -- I have neither product on hand, so... need to buy.
Old 04-17-2013, 01:22 PM   #78
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
I used "aircraft adhesive remover", most auto stores carry it. I had the door frame cleaned in a couple of minutes. It also worked great to get the 50 taped on hooks off the interior fiberglass.
Old 04-17-2013, 01:26 PM   #79
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Is the stuff at this link what you're talking about, Jared?
I've been trying to remove contact paper glue residue from spots in my trailer ever since I got it!
Francesca
Old 04-17-2013, 01:28 PM   #80
Jared J's Avatar
Kansas
Yep. It's fine on the fiberglass. I would be very careful about getting it on ensolite, and test a spot you didn't care about first.
Trillium Door Gasket noah Problem Solving | Owners Helping Owners 17 07-30-2020 08:11 PM
Door gasket question Sharry B Care and Feeding of Molded Fiberglass Trailers 1 05-13-2012 12:28 PM
Door gasket material floyd Care and Feeding of Molded Fiberglass Trailers 13 07-23-2009 08:00 PM
Dometic RM2201 Door Gasket Nate M Problem Solving | Owners Helping Owners 4 06-24-2009 12:29 AM
door trim or gasket Ricky 4 Care and Feeding of Molded Fiberglass Trailers 8 02-08-2009 02:16 PM
