Door handle fell off in my Boler - Fiberglass RV
Old 01-20-2015, 01:41 PM   #1
Trailer: Boler
Hi there,
I have a 1975 Honey Boler, and last night, I tried to pull the door shut from the inside, and the door handle came off right in my hand.
I'm still able to get it to work, but I can't lock it from the inside now because in order to get the pin in, I need to pull the door in fairly hard. But when I try to do that, the handle just comes off again. Here's a photo:
What should I do? Sorry if this is a super basic question.
Thanks.
Emilie W. is offline   Reply With Quote
Old 01-20-2015, 01:52 PM   #2
Ian G.'s Avatar
This is common
Just slightly loosen the set screw (allen key) on the handle, reinstall the handle then tighted the set screw. If it continues to come loose you can drill a small indend in the square latch rod where the screw tighten against to help the set screw seat better.
Ian G. is offline   Reply With Quote
Old 01-20-2015, 05:03 PM   #3
I installed a handle on the inside of the door of our Uhaul to pull it shut. Prevents stress on the latch handle.
Old 01-20-2015, 07:47 PM   #4
Jon in AZ's Avatar
Scamp puts a metal pull loop in the middle of the door from the factory. Works great!
Old 01-20-2015, 08:56 PM   #5
Trailer: Boler
That worked, Ian. Thank you!
boler
Redoing Burro door hinges - door fell off! AndyW Problem Solving | Owners Helping Owners 10 12-30-2015 12:39 PM
Taking off burro door handle jaywginther Modifications, Alterations and Updates 5 03-09-2013 09:15 PM
Broken axle help in Lafayette, LA? (was: whee l fell off (mostly)) CeliaL Problem Solving | Owners Helping Owners 27 03-23-2011 08:31 AM
U-shaped Shelf fell down!!!!! Mary Lynn K. Problem Solving | Owners Helping Owners 4 06-13-2008 01:08 PM
Potable fresh water tank spigot fell off brendaross Problem Solving | Owners Helping Owners 1 09-18-2007 05:13 PM
» Trailer Showcase
Trillium
JR MASTER
TBD
jmark
